As-Built
AutoCAD
3D Export Failure - Object Could Not be Converted in As-Built for AutoCAD Plant
When using As-Built™ for AutoCAD® (in combination with Autodesk Plant 3D 2021) to export pipe runs after modeling with any spec in the ANSI_Specs2019.txt file, you will see an error message like the one in the image below.  The reason the components cannot be converted to Plant 3D is due to a change in naming convention by Autodesk of their 2021 Plant 3D specs.
Solution
To export pipe runs with As-Built for AutoCAD using Plant 3D 2021:
  1. Download the new ANSI_Specs2021.txt file. Use this version instead of the previous version for 2019 ( the new file will be included in the next release of As-Built for AutoCAD).
  2. Select Load Plant Specs on the As-Built Plant tab of the ribbon and load the downloaded "ANSI_Specs2021.txt" file.
  3. Model piping using Walk The Run with any spec.
  4. Use Apply Constraints Strategy 2 to ensure coplanar/coaxial runs and decrease likelihood of "waterdrops" after export.
  5. Use the As-Built Export tool to create Plant 3D objects.
    1. NOTE: If you use any of the FARO® Modified Specs to extract piping from the point cloud, you will need to add the Plant3D spec files to the Pipe Specs of your current Plant 3D project.
