2026
2025
Feature Reducibility in CAM2
Feature Reducibility is a term used to describe that one type of feature can be used like another type in some situations, even though the ‘reducible feature’ cannot be seen.
Download a PDF of this article:  MS002: Feature Reducibility
Reducible Feature Types
There are 3 ‘reducible’ feature types:
MS002Fig1.jpg Point: Is not 'feature reducible', nor does it have a vector (direction).
Line: Is not ‘feature reducible'.
The vector (direction) is shown by the arrow, and is determined by the 1st to 2nd point measured.
Plane: Is not 'feature reducible'.
The vector (direction) is shown by the arrows, relevant to the compensation direction when measured.
Reducible Features
All geometrical features contain at least one ‘reducible feature’ type, which are used as the ‘anchor’ for dimensions, coordinate systems, alignments & constructions. The following diagrams below shows by feature, it’s ‘reducible feature’ and where they are positioned.
Circle (Arc): 3 'Reducible' Features:
Point - at the center Plane - which it is projected onto Line - through the center, parallel to planes vector (GD&T datum only)
Round Slot: 3 'Reducible' Features:
Point - at the center Plane - which it is projected onto Line - from arc center to arc center
Rectangular Slot: 3 'Reducible' Features:
Point - at the center Plane - which it is projected onto Line - running center along length
Ellipse: 3 'Reducible' Features:
Sphere: 1 'Reducible' Feature:
Cylinder: 1 'Reducible' Feature:
Cone: 2 'Reducible' Features:
Point - at the apex Line - through the center
Torus: 2 'Reducible' Features:
Point - at the center Plane - parallel to the section center circle
Therefore, when creating constructions, the option ‘treat as’ refers to the reducible feature.
See Also
Help Sheet, MS002
