Measure X
Measure 3/4
Deleting Registry Entries after Uninstalling Measure 4 and X
  1. From the Start Menu, go to Run…
  2. Type regedit and click OK
  3. Expand the tree to the following location: HKEY_CURRENT_USER\SOFTWARE\FARO
  4. Highlight the FARO folder, then from the menu select Edit>Delete
  5. Then expand the tree to this location: HKEY_LOCAL_MACHINE\SOFTWARE\FARO
  6. Highlight the FARO folder, then from the menu select Edit>Delete
  7. From the menu, go to File>Exit
  8. Restart the computer, then re-install FARO Software.
Keywords: registry, regedit, registries, delete, uninstall
