Moving the Feature Window in Measure 10
The feature window in Measure 10 can be be moved to a different location. If you are not able to move this window, perform the following:
-Close the Measure software
-Hold down the CTRL key on the keyboard
-Double click on the Measure 10 Icon while holding the CTRL key down to re-open Measure.
The software display and panels is now reset to factory settings and the window can be moved again.
Features window, detached, blocks
