Software Download, Installation, and Release Notes for SCENE Capture and Process
FARO SCENE Screen and Box
Note: SCENE Process 2019.1 is the last supported version of SCENE Process software and should only be used with SCENE Capture 2019.1. SCENE Process functionality is available in SCENE 2019.1 and later versions.
Quick Steps
  1. Click the links below to download the latest FARO® SCENE Capture and Process software. For earlier versions of Capture, click here. For earlier versions of Process, click here.
    Release Date Version
    19 Jan 2021 SCENE Capture 2020.0.5   Download
     9 Aug 2019 SCENE Process 2019.1   Download
  2. It may take a several minutes to complete the download. Do not close your browser or shut off your computer while the download is in process. When the download is complete, the SCENE Capture and Process installation setup.exe file appears in your browser's download folder.
  3. Download the Release Notes to learn what is new in the latest version.
  4. Check that your Microsoft Windows operating system is compatible and that your computer meets the recommended system requirements.
  5. Install the software.
    • For SCENE Capture, because it does not require a license key, just double-click the setup.exe file, read and accept the use conditions, then click Next on all the windows until the installation is complete. Click Finish and the software opens. If you are upgrading, uninstall the old version and install the newer one.
    • For SCENE Process, because it does require a license key, use the installation instructions and in the last step follow the link to activate or update your SCENE Process license Product key.
Video
Tour the Scene Capture user interface running on the FARO® Freestyle tablet. See 3D data appear as you scan with the Freestyle, watch the point cloud build up, and learn how to take measurements. Cannot access YouTube? Download Here
Back to top
When scanning with the Freestyle hand-held laser scanner, you use SCENE Capture, SCENE Process, and SCENE to create detailed point clouds of real-world environments.for documentation, inspection, and measurement purposes. This software is seamlessly integrated, making it quick and easy to work with.
  • SCENE Capture is the free, unlicensed software that comes with the tablet computer you get with the Freestyle. Using Capture, you can check and manipulate the quality of your 3D data, point cloud, and emerging visualization as you scan. Measurements can be taken directly from Capture. Using Capture, only single scans are possible. To register multiple scans, you must purchase SCENE Process.
  • SCENE Process is FARO licensed software that runs on a laptop or workstation. You must purchase it separately from the Freestyle. You move the captured point cloud to Process to automatically improve the scan and visualization quality. If needed, you can export the point cloud from Process to manipulate it further in other software, such as SCENE.
  • SCENE is FARO licensed software that runs on a laptop or workstation. You can use the powerful features in SCENE to further process and manage scanned data. Features include automatic object recognition, scan registration and positioning, and high-quality scan colorization.
CAUTION: The version number of SCENE Capture used to create the point cloud must be the same or later than the version of SCENE Process or SCENE. For instance, If the point cloud comes from SCENE Capture 5.5 and you are using version SCENE Process 5.4, the file will not open. You must upgrade to SCENE Process or SCENE 5.5 or later to open the files. If the situation is reversed, with the point clout coming from SCENE Capture 5.4 and you are using SCENE Process 5.5 or SCENE 5.5 the file will open correctly.
You can download either the latest or earlier versions of the Capture and Process software from this article.
Prepare
Time to Complete 20 minutes
Skills Needed
  • General computer skills
Prerequisites
  • Internet connection
  • Computers you use with Capture and Process
Supported Hardware
  • Freestyle Objects
  • Freestyle3D X
  • Freestyle3D
Back to top
SCENE Process Installation
Installing the latest SCENE Process version overwrites the existing version. If you want, you can change the install location so that the latest version does not overwrite the version you are currently using. This enables you to run multiple versions of SCENE Process on the same computer.
  1. Ensure you have administrator privileges on your computer. If you do not, contact your IT department.
  2. Turn off all anti-virus and firewall software, as they can affect installing the software.
  3. Once you have successfully downloaded the software, double-click the SCENE Process setup.exe.
  4. You may be prompted to allow SCENE Process to make changes to your device. Click Yes.
  5. The Select Setup Language dialog box appears. Select the desired language and click OK.
  6. Continue following the prompts to accept the license agreement, choose an installation folder, choose the components to install, and create a Start Menu folder.
  7. When the Select Additional Tasks window appears, click Enable automatic update checking to be updated automatically to the latest version of SCENE Process when an upgrade is available. Automatic upgrades will not work if you have not checked this box.
  8. Follow the remaining prompts to complete the installation process and click Finish.
    The installation application puts the SCENE Process shortcut ProcessShortCut.PNG on your desktop and SCENE Process opens.
    Note: If you turned off anti-virus and firewall software before installing SCENE, turn them back on. If you do not know how to do this, contact your IT department.
  9. Proceed to Activate or Update a SCENE Process License Product Key or Dongle to activate your SCENE Process license.
SCENE Capture Installation
Installing the latest SCENE Capture version overwrites the existing version. If you want, you can change the install location so that the latest version does not overwrite the version you are currently using. This enables you to run multiple versions of SCENE Capture on the same computer.
  3. Once you have successfully downloaded the software, double-click the SCENE Capture setup.exe to begin installation.
  4. You may be prompted to allow SCENE Capture to make changes to your device. Click Yes.
  6. Continue following the prompts to accept the license agreement, choose an installation folder, choose the components to install (ensure all drivers are selected) and click Next.
  7. Click Next again to create a Start Menu folder.
  8. When the Select Additional Tasks window appears, click Enable automatic update checking to be updated automatically to the latest version of SCENE Capture when an upgrade is available. Automatic upgrades will not work if you have not checked this box.
  9. Follow the remaining prompts to install additional drivers and complete the installation. Click Finish to restart your computer to finish the installation process.
    The installation application puts the SCENE Capture shortcut scenecapture_icon.PNG on your desktop and SCENE Capture opens
  10. Proceed to Activate or Update a SCENE Capture License Product Key or Dongle to activate your SCENE Capture license.
