Sync Changes from SCENE to Sphere XG
Before you sync changes in projects:
  • Only Sphere XG projects containing data uploaded from Stream and SCENE 2024 or later will show content once they are downloaded.
    • For uploaded projects from Stream, only Focus and Blink data are compatible with SCENE. Orbis uploaded data is still not compatible at this time.
  • Using SCENE to add data in WebShare Cloud Migrated projects will upload the data to Sphere XG, but the data will not be visible in the Sphere XG viewer.
Once you have uploaded a project to Sphere XG it is possible to make changes in your SCENE project and to synchronize those changes with Sphere XG. Once the changes are synchronized they will be visible in the Sphere XG Viewer. The following changes will be visible in the Sphere XG Viewer after syncing from SCENE:
  • Add and remove scans
  • Modify the registration of the existing scans
  • Modify scans: re-process, manually clean points, etc.
  • Modifications in the Project Point Cloud
This is a major improvement compared to the existing WebShare Cloud (WSC) workflow where a new WSC project had to be created for every project update. With Sphere XG it is easy and efficient to perform incremental updates on uploaded projects.
Synchronize a Project
To synchronize your changes you just need to save the SCENE project. Sphere XG will then automatically show the Sync button within the Sphere XG tile indicating that your project is no longer in sync with the Sphere XG project.
If the sync button is available due to the previous save of the project (and you click it), SCENE will automatically save any changes since the last save before synchronizing.
