FARO Zone 3D
2026
2025
2022
FARO Zone 3D Keyboard Shortcuts
In this article you can find the keyboard shortcuts for FARO Zone 3D.
Shortcuts
  • Esc - When your cursor indicates you have a multi-step drawing or editing tool active or are in the midst of adding positions to an animation path, press Esc to back up one step. Esc also cancels single-step commands.
  • Enter -  Press to finish many commands.
  • Space bar -  After using a drawing tool, press to repeat the same tool.
  • Ctrl+A -  Select All. This selects all objects placed on the scene (points, models, lines, etc.) and allows re-positioning in relation to the ground-plane. Note: You can also use the Delete key to remove all selected items.
  • Ctrl+Z -  Undo; works for up to 10 previous operations.
  • Ctrl+C -  Copy.
  • Ctrl+V -  Paste.
  • Ctrl+X -  Cut.
Two Letter Command Shortcuts
Draw Commands
  • A3 - 3-point Arc
  • AR - 2 End-points and Middle
  • C2 - 2-point Circle
  • C3 - 3-point Circle
  • C4 - 4-point Sphere
  • CV - Curve
  • EP - Ellipse
  • LC - Continuous Line
  • LS - Single Line
  • OR - Ortho Mode
  • PO - Point
  • R2 - 2-point Rectangle
Edit Commands
  • AG - Align
  • BR - Break
  • CO - Copy
  • ER - Delete (Erase)
  • EX - Explode/Ungroup
  • FI - Fillet/Chamfer
  • GT - Group
  • GU - Ungroup
  • IS - Invert Selection
  • LM - Layer Manager
  • MV - Move
  • OF - Offset
  • RO - Rotate
  • SA - Select All
  • SN - Snip
  • TR - Trim/Extend
  • XT - Trim/Extend
File Commands
  • BI - Bitmap Import
  • CD - Coordinate Data Table
  • FL - Drawing Load
  • FM - File Merge
Text/DIMS/Measure
  • DA - Dimension Angle
  • DL - Dimension Linear
  • DR - Dimension Radius
  • MA - Measure Area
  • MK - Measure Marker
  • OL - Object Length
  • TL - Text Line
View Commands
  • TB - Send to Back
  • TF - Bring to Front
  • ZA - Zoom All
  • ZW - Zoom Window
