FARO CAD Zone
First Look Pro
Manually Install SQL Server 2008R2 Configured for First Look Pro 5
To manually install SQL Server 2008R2 configured for First Look Pro 5, use the procedure below.
Details
  1. Download either 32 or 64 bit version of SQL Server from Microsoft (first 2 files in list):
  2. After setup has started, choose New installation or add features to an existing installation.
  3. Allow Setup support files to run, then choose New installation or add shared features and click Next.
  4. After agreeing to License Terms, select Database Engine Services and SQL Client Connectivity SDK.  Do NOT click SQL Server Replication.
  5. Enter “SQLCADZONE2” in the Named instance field.
  6. For the service account change it to “NT AUTHORITY\SYSTEM”
  7. In Account Provisioning choose the Mixed Mode option.
  8. The “SA” account password is “Yr8Nq4p^8utg33(@” (without quotes).
  9. Click Next and allow the installation to complete.
When installing First Look Pro 5, choose the option to NOT install SQL Server. Note: FLP can be run on SQL 2008R2, SQL 2012, SQL 2014 and should run on 2016 as well but it has not been tested.
  • Was this article helpful?
