Change the Default Language of Measure 10
Follow the steps below to change the language of Measure10 Software;
  1. Delete the CAM2Measure folder in C:\Users\[username]\AppData\Roaming
  2. From the Command Prompt go to the Measure10 installation folder and then type:
CAM2Measure.exe –culture:EN
This command changes the software language into English.
To change the language into German you can replace the EN with DE.
CAM2Measure.exe –culture:DE
Note: This solution can be used only to change the language of the software between German and English languages.
This solution only works with Windows 7 operating system!
