Turn off the Tolerance Color Bar in the CAD View of Measure 10
Measure With Box
Quick Steps
Here is all you have to do. Click the link for details.
  1. Edit the preference settings by going to Preferences Preferences Icon > Display > CAD view.
  2. Uncheck Display Color gradient in CAD View, then click OK or Save to Default.
To remove the tolerance color bar that appears in the CAD view you must change a display preference setting.
Preference settings can be applied to the current measurement file, or saved as the default and loaded each time you start Measure. You can change preferences to meet your needs. When you change the default Preferences, they appear with pencil icons beside them to indicate their changed status. Edited preferences remains changed until you exit the Preferences group without saving, click OK to confirm the changed settings for the current measurement file, or save the changes to make them the new default so that they load each time you start Measure.
Prepare
Time to Complete 2 minutes
Skills Needed
  • Knowledge of Measure
  • General computer skills
Supported Software
  • Measure 10.5.3 and later
Edit the CAD View Display Preference Setting for Color Gradient
  1. From the Home tab on the top menu, click the Preferences group Preferences Icon.
  2. In the left panel, click Display, click the CAD view tab in the right panel, and scroll to the bottom.
    CAD View Display Preferences Dialog Box
  3. Uncheck Display Color gradient in CAD View.
  4. Click OK or Save to Default.
If you need to revert to the most recently saved default settings, click Reset to Default.
See Also
color scale, tolerance indicator, minimum, maximum, out of tolerance, remove the color bar
  • Was this article helpful?
