Uninstall Measure 10 Manually
Measure With Box
IMPORTANT NOTE: This full / manual uninstallation procedure is obsolete and is only compatible with Measure 10.1 and lower. It has been replaced with a Clean Up Tool. Click here to download.
This procedure should only be performed if you can not download and use the Clean Up Tool.
After using Add/Remove Programs in the Control Panel to do a standard uninstall of Measure 10, these steps will remove remaining items from you computer including the registry values and profiles.
Please see below for directions for step by step manual removal. NOTE: If some of the directories to delete do not appear, that step can be skipped. Make sure you have hidden files enabled in the folder view options.
Windows Vista / Windows 7
  1. Run uninstall program for Measure 10
    1. Select Windows Start -> All Programs -> FARO -> Uninstall CAM2 MEASURE
    2. Select the “Yes” button to confirm uninstall of product.
  2. Remove these files from the C:\Users\<USER-ACCOUNT>\Documents\CAM2 MEASURE 10
    1. documentpropertytemplate.pdt
    2. documentPropertyInfo.cmb
    3. headerInformation.hed
  3. Remove these file folders from: C:\Documents and Settings\All Users\Application Data
    1. FARO
    2. FARO Technologies
  4. Remove all FARO and software directory: C:\Users\<USER-ACCOUNT>\AppData\Roaming
  5. Remove all FARO and software directory: C:\Users\<USER-ACCOUNT>\AppData\Local
  6. Remove directory: C:\Program Files\FARO\CAM2 MEASURE 10
  7. Remove files from: C:\Program Files\Common Files\FARO Shared
  1. CapturePoint.WAV [Shared by FARO Measure X]
  2. FaroArmUSB_1033.chm [Shared by FARO Measure X]
  3. FaroArmUsb5.dll [Shared by FARO Measure X]
  4. FaroArmUsb5_1033.dll [Shared by FARO Measure X]
  5. FAROAtlServerApp5.exe [Shared by FARO Measure X]
  6. FaroAtlServerApp5_1033.dll [Shared by FARO Measure X]
  7. FaroCab.dll [Shared by FARO Measure X]
  8. FaroBlueToothConfig.exe
  9. FaroBlueToothConfig.exe.config
  10. Interop.FAROATLSERVERAPP5Lib.dll
8. Remove directory: C:\Program Files\Common Files\Aladdin Shared
  1. This assumes you have no other Aladdin HASP products installed on this machine.
  2. NOTE: A reboot may be required to release any locks on files contained in this directory structure.
Registry changes
1. Remove key entries:
  1. HKEY_CURRENT_USER\Software\FARO Technologies\CAM2 Measure
Windows XP
File system changes
    1. Select Windows Start -> All Programs -> FARO -> Uninstall CAM2 MEASURE 10
  2. Remove these files from: C:\Documents and Settings\<USER-ACCOUNT>\My Documents\CAM2 MEASURE 10
    1. FARO
  4. Remove directory: C:\Documents and Settings\<USER-ACCOUNT>\Application Data\CAM2 Measure\10.0
  5. Remove directory: C:\Program Files\FARO\CAM2 MEASURE 10
  6. Remove files from: C:\Program Files\Common Files\FARO Shared
  7. Remove directory: C:\Program Files\Common Files\Aladdin Shared
Registry changes
Uninstall, uninstallation, clean, Measure 10, M 10, reghost, re-image, reinstall
