Measure X
Measure 3/4
Upgrading Measure 4 (.Sat) Files to Measure X (.Fce) Files
Two things are required before following the below steps:
  1. The user has to make sure Measure 4.0 and Measure X are installed on the same system before proceeding
  2. The user's portlock has to be enabled to convert 4.0 files to X files. A new portlock may have to be assigned if the following steps do not work. Contact Customer Service for more information.
In Measure X:
  1. Go to File> Import Project Files
  2. Find the file through the path to the location of the .sat file. Then click on the Open button.
  3. *As soon as this file is saved, the format will be the native format of Measure X (.fce)
Keywords: header file, header, xml
