Software Download and Installation for SCENE Process
Note: SCENE Process 2019.1 is the last supported version of SCENE Process software and should only be used with SCENE Capture 2019.1. SCENE Process functionality is available in SCENE 2019.1 and later versions.
Quick Steps
  1. Click the links below to download the latest FARO® SCENE Process software. For earlier versions of Process, click here.
    Release Date Version
     9 Aug 2019 SCENE Process 2019.1   Download
  2. It may take a several minutes to complete the download. Do not close your browser or shut off your computer while the download is in process. When the download is complete, the installation setup.exe file appears in your browser's download folder.
  3. Install the software.
SCENE Process Installation
Installing the latest SCENE Process version overwrites the existing version. If you want, you can change the install location so that the latest version does not overwrite the version you are currently using. This enables you to run multiple versions of SCENE Process on the same computer.
  1. Ensure you have administrator privileges on your computer. If you do not, contact your IT department.
  2. Turn off all anti-virus and firewall software, as they can affect installing the software.
  3. Once you have successfully downloaded the software, double-click the SCENE Process setup.exe.
  4. You may be prompted to allow SCENE Process to make changes to your device. Click Yes.
  5. The Select Setup Language dialog box appears. Select the desired language and click OK.
  6. Continue following the prompts to accept the license agreement, choose an installation folder, choose the components to install, and create a Start Menu folder.
  7. When the Select Additional Tasks window appears, click Enable automatic update checking to be updated automatically to the latest version of SCENE Process when an upgrade is available. Automatic upgrades will not work if you have not checked this box.
  8. Follow the remaining prompts to complete the installation process and click Finish.
    The installation application puts the SCENE Process shortcut ProcessShortCut.PNG on your desktop and SCENE Process opens.
    Note: If you turned off anti-virus and firewall software before installing SCENE, turn them back on. If you do not know how to do this, contact your IT department.
  9. Proceed to License Activation for FARO Software to activate your SCENE Process license.
