Quantum X.S
Quantum X.M
Quantum X.E
Quantum S Max
Quantum M Max
Quantum E Max
Gage Max
Gage
Design ScanArm 2.0
Design ScanArm 2.5C
Probes, Adapters and Extensions for the Quantum FaroArm/ScanArm and Gage
If you want to use the probes from an older FaroArm® model with newer Gen 5 and Gen 6 models, you will need an adapter. This is because the probes for newer models snap into place whereas the probes for older models screw into place. If you have any questions, or would like to make a purchase, please contact your regional Sales Agent.
The “Probe, Stylus, and Adapter Interfaces for all FaroArm Models” article lists the various probe interfaces offered over the years and their corresponding compatibility with FaroArm models.
Standard iProbes
20540-XXX is the new standard iProbe, complete with a programmed certified diameter. This means that the FaroArm recognizes the diameter of the probe automatically. This enables probe changing without recalibration.
Standard Probes Include
  • (20540-001) 3MM (Included with purchase; Quantum,Gage)
  • (20540-002) 6MM (Included with purchase; Quantum)
  • (20540-003) 1MM
  • (20540-004) 2MM
  • (20540-005) 8MM
  • (20540-006) 10MM
  • (20540-007) 12MM
Universal Adapter
20780 is the custom probe adapter, or the Universal Adapter, indicated by a black body. It accepts any probe with M4 threads. Unlike with the standard iProbes the user must manually enter the probe tip into the driver.
Who Is It For?
  • If you use multiple probe tips when not regularly required
  • If you want flexibility to create custom sensors when needed
What are the Standard Accessories from FARO®?
  • (21765-003) 1MM Ball Probe
  • (21765-004) 2MM Ball Probe
  • (21765-001) 3MM Ball Probe
  • (21765-002) 6MM Ball Probe
  • (21765-005) 8MM Ball Probe
  • (21766-001) 10MM Ball Probe
  • (21766-002) 12MM Ball Probe
  • (21564) Point Probe
  • (21563-001) 50MM Ceramic Probe Extension
  • (21563-002) 100MM Ceramic Probe Extension
  • (21563-003) 50MM Carbon Fiber Probe Extension
  • (21563-004) 100MM Carbon Fiber Probe Extension
  • (21562) 21MM Swivel Joint
Extension Adapter
21460, the extension adapter, accepts threads at the head and the rear interfaces of the threads on the handle (see right). It is part of the new extension kit, 21604. You must manually enter the size of the probe tip within the Probe Management dialog box.
Who Is It For?
  • If you have a probe tip with extensions longer than 100mm
  • If you have a legacy probe extension kit
  • If you have M6 threaded probes
TrackArm Adapter
21583, or the TrackArm Adapter, is the kinematic adapter used for location of the TrackArm. It has M6 threads, but has a hard-coded diameter of 7/8”. It does not support use of M6 threaded probes.
Who Is It For?
  • If you own a Quantum series FaroArm and a FARO Laser Tracker and you want to implement our Super 6DOF solution
TP-20 Adapter
20735, or the TP-20 Adapter, is the kinematic adapter used to communicate to a Renishaw TP-20 probe. You must manually enter the size of the probe tip into the Probe Management dialog box.
Who Is It For?
  • If you want to purchase or use an existing Renishaw TP-20
