Quantum X.S
Quantum X.M
Quantum X.E
Quantum S Max
Quantum M Max
Quantum E Max
Gage Max
Gage
Fusion
Prime
Platinum
Legacy Quantum
Titanium
Advantage
Digital Template
Design ScanArm
Design ScanArm 2.0
Design ScanArm 2.5C
Forensic ScanArm
Mount Stability and Single Point Articulation Test (SPAT) with the FaroArm
The following video depicts the SPAT Test using FaroArm driver v6.1.0 and later. If you are using an earlier driver please see this article: Single Point Articulation Test (SPAT) in Measure
In this video, a FARO® Engineer shows you how to do the SPAT test to check the repeatability of the FaroArm X, Y, and Z coordinates throughout its full range of motion.
NOTE: You will get better results if you hold the probe tip at a 45 degree angle from vertical, instead of straight-up vertical, and to sweep the FaroArm by holding it by the lower tube, instead of the upper tube.
Video
