Quantum X.S
Quantum X.M
Quantum X.E
Quantum S Max
Quantum M Max
Quantum E Max
Fusion
Platinum
Legacy Quantum
Titanium
Advantage
Design ScanArm
Design ScanArm 2.0
Design ScanArm 2.5C
Forensic ScanArm
Scanning Accuracy effects on Parts When Using Powder Spray
Accuracy degradation is difficult to quantify because it depends on how much and how evenly you spray.
The attached document is a study done by the University of Michigan, that evaluates the effects of powder spray on optical measurements. They used a White light system.
The bottom line is that they used a laser profilometer to measure the topography of the sprayed surfaced and found that a sparsely sprayed surface can have high spots of up to 100microns (possibly caused by large droplets) and that a more dense evenly sprayed surface could have a highs of up to 62microns. Low spots were measured in the 40 to 50micron range.
As long as you apply one nice/even coat, 50 microns (0.002") should be a good estimated average coat thickness.
Click here to download: Evaluation of Powder Spray Effect
llp, scanarm, laser line probe, spray, coat, accuracy
