Quantum X.S
Quantum X.M
Quantum X.E
Quantum S Max
Quantum M Max
Quantum E Max
Gage Max
Gage
Design ScanArm
Design ScanArm 2.0
Design ScanArm 2.5C
Forensic ScanArm
Workholding Kit (900-000034-000) for the 8-Axis
The FARO® 8-Axis Workholding Kit (for use in conjunction with the 8-Axis), provides many solutions to workholding challenges for large or odd shaped parts. Solid and repeatable workholding is a must for accurate measurements, scans, and scan registration. P/N: 900-000034-000, contact your regional FARO account representative for ordering information.
Warning: The FARO 8-Axis maximum weight capacity is 220lbs (100kg). The user assumes all responsibility and risk for ensuring parts mounted to the 8-axis are secure, load balanced, and does not present a tipping hazard. FARO Technologies, Inc. disclaims any liability for injury, death or damages resulting from the use thereof.
Kit Contents
Item# Qty Description   Item# Qty Description
Num1.png 1 Case   Num10.png 16 M6 Centered Slide-in T-Nut
Num2.png 4 Rail, T-Slot, 25 x 25 x 300mm   Num11.png 8 M6 x 16 Flanged Button Head Socket Cap Screw
Num3.png 4 Rail, T-Slot, 25 x 25 x 225mm   Num12.png 4 M6 x 25mm, Female/Female Standoff
Num4.png 4 Rail, T-Slot, 25 x 25 x 150mm   Num13.png 50 M6 x 10 Button Head Socket Cap Screw
Num5.png 4 Tall Inside Corner Bracket   Num14.png 4 Load-Rated Bumper (22lbs), M6 x 18mm Threaded Stud
Num6.png 4 Gusseted Inside Corner Bracket   Num15.png 4 M6 x 80mm Threaded Rod
Num7.png 12 End Cap with Push-in Fastener   Num16.png 12 M6 Flanged Nut
Num8.png 4 4 Hole - Straight Flat Plate   Num17.png 1 Hex Key, T-Handle, 4mm
Num9.png 16 M6 Double Slide-in T-Nut
Application Examples
Basic Usage and Tips
While its not possible to cover every workholding configuration, below are some basic guidelines to keep in mind.
T-Nuts
  • When using T-Nuts, be sure the small protrusion of the thread faces down into the channel of the rail.
  • Use of the Double T-Nuts can simplify assembly and save time when using flat plates and corner brackets.
  • Whenever possible "preload" T-nuts with the fastener(s). Slide the assembly into the end of the rail, position and then tighten. This will eliminate the task of aligning the fastener to threaded hole afterwards.
Attaching Rails to the 8-Axis Plate
When attaching rails directly to the 8-Axis Plate, it is important observe the mounting locations that will allow the fasteners to pass through the hole and thread into the corresponding T-Nut.
  1. Most of the holes on the 8-Axis plate are threaded, the locations of non-threaded through holes are shown in red below. To eliminate unwanted movement it is recommended to have at least two mounting points per rail section.
  2. Using two M6x16 Flanged Screws Num11.png and a M6 Centered Slide-in T-Nuts Num10.png, assemble them through the plate as shown (using non-threaded holes). Leave the fasteners loose to allow the rail to slide over them in the next step.
  3. Slide the desired Rail over the two T-Nuts. (The 300mm rail Num2.png is long enough to span the diameter of the plate.)
  4. Position the rail as desired and tighten the two screws.
