3D Laser Scanner
Focus Core
Focus Premium
Focus Premium Max
Download and Release Notes for FARO Stream
The FARO® Stream App can be downloaded directly from: Stream - Apple App Store | Stream - Google Play. You will also find QR codes on the Focus Premium and Orbis Quick Start Guide that will take you to FARO Sphere and the download for the FARO Stream app. If you are using an Android device and do not have access to the Google Play, a direct download and installation instructions are provided below.
Direct Download and Install (Android APK)
The FARO Stream App can be installed on your Android smartphone/tablet without Google Play using the FARO Stream App APK file.
Adjust Device Security Settings
By default, most Android devices restrict installation of apps that do not come from Google Play. Before you can download and install the FARO APK file/app on your Android device you will need to adjust some settings:
Note: The procedure and menus can differ between devices and Android versions.
  1. Open the Settings page on your device.
  2. Search for “unknown”.  In the results, select "Install unknown apps" or "Unknown sources".
  3. Scroll down to the "My Files" app and enable it.
Your device can now install apps (.apk files) that do not come from Google Play. After installation, you can deactivate these permissions.
Installation of the Stream APK
Once you have enabled your device to allow APK installation:
  1. Download the FARO Stream APK to your device.
  2. Open the My Files app on your device, under "Downloads" locate and tap on the Stream APK file.
  3. When prompted, confirm the installation and the app will be installed.
Note: Automatic updates for the manually installed APK file will not occur. You must download and install the update manually using the procedure outlined above.
FARO Stream is a mobile App allows you to:
  • Control your Orbis, Blink, and Focus Premium scanner
  • Pre-register captured scans directly in the field to get confidence on data completeness and reduce off-site registration failures
  • Collect complementary data as annotations marked in the scan with image or file attachments
  • Upload captures data directly into Sphere for immediate project sharing with stakeholders.
Recommended Mobile Devices:
  • iPhone 11 (iOS 15.4) with minimum 64GB Capacity for small to medium projects (> 50 scans per project)
  • iPad Pro (12.9 Inch, 5. Gen., iOS 15.4) with minimum of 128GB Capacity
  • Android 12, minimum 128 GB (e.g. Google Pixel 5 for small and medium projects)
Release Notes
This article lists the Release Notes for each version of the FARO Stream App to date. The current version release notes are displayed at the top of the article. Previous revisions are contained in expanding sections below.
FARO Stream 4.3.1 Release Notes - August 2026
This release of Stream requires Blink firmware 1.1.0 (or higher) and Orbis firmware 4.3.1 (or higher) to work with the scanners. The firmware of the scanners with older firmware version can still be updated via Stream. Important: Stream does not support downgrading to previous firmware versions.
IMPORTANT: If projects, clusters, or scans are deleted from Sphere XG, the synchronization with Stream will delete them from Stream, too, even if they have local changes. Such local changes, for example, an annotation, will be lost
Improvements
  • Improved scan start handling to prevent application instability when the scan button is triggered in an unexpected state.
Fixes
  • Various bug fixes to address several runtime issues identified in production environments, including JavaScript, React Native, and native platform crashes.
FARO Stream 4.3 Release Notes - August 2026
Improvements
  • The new Project 3D View for Focus and Blink scanners shows all visible scans in a three-dimensional point cloud that you can rotate, pan, and zoom using familiar touch gestures. By default, the point cloud is colored by elevation (height), but you can change the colorization of the points to emphasize different characteristic of the scan. See the Stream documentation for more information.
  • The first Blink or Focus scan in a project now automatically aligns to the grid direction without affecting registration, making project orientation easier to set up.
  • Stream now automatically syncs the time on Focus and Orbis Scanner.
  • Firmware update dialogs now provide direct access to firmware release notes.
  • Various improvements to scanner management, device status reporting, and the user interface.
FARO Stream 4.2.4 Release Notes - July 2026
Improvements
  • You can now reliably recover usable Orbis scan data after unexpected interruptions. The new Orbis scan-repair workflow automatically handles interrupted scanning sessions, enabling you to recover available progress and add new scans to your project.
FARO Stream 4.2.3 Release Notes - June 2026
Improvements
  • Added a clear Orbis camera status message to prevent scaning during data download or recovery.
  • Included automatic device information when exporting Orbis logs to improve diagnostic analysis.
  • Updated Orbis outlier removal terminology to align with the new filtering feature in Sphere XG.
Bug fixes
  • Various minor improvements and corrections.
FARO Stream 4.2.2 Release Notes - April 2026
This release of Stream requires Blink firmware 1.1.0 (or higher) and Orbis firmware 4.3.0 (or higher) to work with the scanners. The firmware of the scanners with older firmware version can still be updated via Stream. Important: Stream does not support downgrading to previous firmware versions.
Improvements
  • A sensor status for the Orbis scanner is now available in Stream Device Option section. It will help you to make sure that the Orbis scanner is set up correctly and working.
  • When you tap an available device, a page with further sensor status details will open, see figure below.
FARO Stream 4.2.1 Release Notes - March 2026
Improvements
  • Improved context menus
Bug fixes
Orbis Changes
  • Single projects can now be exported to USB via Stream
FARO Stream 4.2.0 Release Notes - Jan 2026
FARO is pleased to announce the release of Stream version 4.2.0 We would like to thank customers who provided valuable product input.
IMPORTANT: If projects, clusters, or scans are deleted from Sphere XG, the synchronization with Stream will delete them from Stream, too, even if they have local changes. Such local changes, for example, an annotation, will be lost.
Improvements
  • Added a scale indicator to DataView.
  • Improved grid spacing.
  • Fixed position marker size for certain display sizes.
  • Enhanced status display for project synchronization.
  • Replaced the Annotations icons with Scan Page in the Radial Menu.
  • Added options to colorize the point cloud in DataView by scan or cluster.
Bug fixes
Orbis Changes
  • Stream 4.2.0 requires a mandatory Orbis firmware 4.3.0 update (and vice versa). Both must be installed together. Existing projects are migrated automatically. Create a backup of your data before updating.
  • Sheets are deprecated in favor of Clusters to unify projects across all FARO scanners.
  • The Orbis scanner now supports the hierarchical cluster structure used by Focus and Blink scanners for consistent project handling. Sheets are no longer available and have been replaced by Clusters. For more details, see the Stream or Orbis manual, available soon on the FARO Knowledge Base (https://knowledge.faro.com/)
  • Improved processing options for Sphere.
  • The USB data structure has changed. *.geolsam files are no longer presented in a single flat list. Instead, they are now organized into subfolders by project. As a result, Connect users will need to navigate one or two levels deeper to locate the files for processing. See Figure 1.
  • For customers who access Orbis datasets via a direct Ethernet or Wi-Fi connection, updating to Connect 2026.0.0 is required. This version is necessary to maintain compatibility with the new Datalogger firmware.
file structure example
FARO Stream 4.1.1 Release Notes - Oct 2025
FARO is pleased to announce the release of Stream version 4.1.1. We would like to thank customers who provided valuable product input.
This release of Stream requires Blink firmware 1.1.0 (or higher) and Orbis firmware 4.2.0 (or higher) to work with the scanners. The firmware of the scanners with older firmware version can still be updated via Stream. Important: Stream does not support downgrading to previous firmware versions.
IMPORTANT: If projects, clusters, or scans are deleted from Sphere XG, the synchronization with Stream will delete them from Stream, too, even they have local changes. Such local changes, for example, an annotation, will be lost.
Improvements
  • Improved support for scanner firmware updates
Bug fixes
  • Fixed some translations and the What's New screen
FARO Stream 4.1.0 Release Notes - Oct 2025
FARO is pleased to announce the release of Stream version 4.1.0. We would like to thank customers who provided valuable product input.
This release of Stream requires Blink firmware 1.1.0 (or higher) and Orbis firmware 4.1.6 (or higher) to work with the scanners. The firmware of the scanners with older firmware version can still be updated via Stream. Important: Stream does not support downgrading to previous firmware versions.
Improvements
  • The user guidance for positioning scans has been improved. The guidance ring has been removed. Users now see only their trajectory: blue where scanning is recommended and yellow where it is not.
  • Stream can now be used to perform on-site compensation (OSC) on the Blink scanner and to generate and print an OSC report.
  • The stitched preview image visible in Sphere XG is now also available for review in Stream.
  • Projects can now be selectively downloaded to a USB stick via Stream.
Bug fixes
  • Several bug fixes and improvements
FARO Stream 4.0.5 Release Notes - Aug 2025
FARO is pleased to announce this release of Stream. We would like to thank customers who provided valuable product input.
  • This release of Stream requires Blink firmware 1.0.3 (or higher).
  • This release of Stream requires Orbis firmware 4.1.7 (or higher) to work with an Orbis mobile scanner. The firmware of Orbis scanners with an older firmware version can still be updated via Stream. Important: Stream does not support downgrading to previous firmware versions.
Improvements
  • Improved robustness of communication with the Orbis scanner
  • Updated pictures for Orbis and Focus scanner models on the device page
Bug Fixes
  • Several bug fixes for use with Orbis
FARO Stream 4.0.4 Release Notes - July 2025
Improvements
  • Improved registration.
  • Prevent duplicate scan names for Blink scanner.
  • Stream will correct the system time on Orbis, if it is incorrect. Orbis firmware 4.1.7 is also required.
  • Raw scan files are removed from Stream after they are uploaded to Sphere XG. This frees up space on the phone or tablet.
  • Scan creation date now synchronized with Sphere XG.
Bug Fixes
  • Prevent inclinometer warnings during a scan for Blink scanner.
  • Logs can now be downloaded via Stream for Orbis scanner.
FARO Stream 4.0.3 Release Notes - May 2025
This release of Stream requires Orbis firmware 4.0.2 (or higher) to work with an Orbis mobile scanner. The firmware of Orbis scanners with an older firmware version can still be updated via Stream. Important: Stream does not support downgrading to previous firmware versions.
Improvements
  • Now recognizes Focus Wi-Fi QR codes
  • Improved robustness in handling intermittent Orbis disconnections
Bug Fixes
  • Fixed an issue where the export service no longer functioned and various other bug fixes
Limitations
  • Point cloud data is not synchronized from Sphere XG to Stream.
  • Deleting a project, cluster, or scan in Stream and syncing will delete the scan from Sphere XG
  • and SCENE.
  • Focus scans are not yet processed in Sphere XG.
  • Syncing from Sphere XG to Stream may remove the Stream registration connections.
  • It's not yet possible to visualize and register scans from both Focus and Orbis in one project.
  • The registration connection lines between the scans are not drawn at certain zoom levels.
    Workaround: Disable and then re-enable the connection line in the DataView settings.
FARO Stream 4.0.2 Release Notes - April 2025
Improvements
  • Added on-boarding screens for Blink and Blink workflows
  • Show a warning when a device is configured for Wifi region "Global", restricting it to the slow 2.4 Ghz band
  • On iOS, implemented a Apple requirement for our Analytics opt-in popup to comply with a standard text provided by Apple
FARO Stream 4.0.1 Release Notes - April 2025
Bug fixes
  • The WiFi region setting did not work with Orbis scanners
Limitations
  • Deleting a project, cluster, or scan in Stream and syncing will delete the scan from Sphere XG and SCENE
    • Workaround: Disable and then re-enable the connection line in the DataView settings
  • Sporadic loss of connection between Orbis and Stream
    • Workaround: Repeat the operation
FARO Stream 4.0.0 Release Notes - March 2025
FARO is pleased to announce the release of Stream version 4.0.0. We would like to thank customers who provided valuable product input.
Improvements
  • Stream now uses the scanner’s inclinometer data.
  • Registration now also uses cloud-to-cloud registration.
  • You can now select the reference scan to be used for manual registration.
  • Improved visualization of loaded and unloaded scan markers.
  • Cluster names can now be reused in projects.
  • Various interface and usability improvements.
  • Various stability improvements.
Bug fixes
  • Various bug fixes
Limitations
  • Deleting a project, cluster, or scan in Stream and syncing will delete the scan from Sphere XG and SCENE.
  • Sporadic loss of connection between Orbis and Stream.
    Workaround: Repeat the operation.
FARO Stream 3.2.3 Release Notes - November 2024
FARO is pleased to announce the release of Stream version 3.2.3. We would like to thank customers who provided valuable product input.
Improvements
  • Stream now supports uploading to Sphere XG while running in the background.
  • Improved ordering of registration for last scans.
  • Newly created projects now open automatically in the DataView.
Bug fixes
  • Resolved an issue that prevented the Focus Core (70m) from being used.
  • Fixed synchronization errors that caused inconsistent project structures.
  • Addressed a problem where the Orbis trajectory was occasionally hidden in DataView.
  • Corrected an issue on the device settings page that occurred when a device was disconnected.
Limitations
  • It's not yet possible to visualize and register scans from Focus and Orbis in one project.
FARO Stream 3.2.2 Release Notes - October 2024
FARO is pleased to announce the release of Stream version 3.2.2. We would like to thank customers who provided valuable product input.
This release of Stream requires Orbis firmware 4.0.2 to work with an Orbis mobile scanner. The firmware of Orbis scanners with an older firmware version can still be updated via Stream. Important: Stream does not support downgrading to previous firmware versions.
Bug Fixes
  • Fixed random crashes and unresponsiveness of the Stream App
FARO Stream 3.2.1 Release Notes - October 2024
FARO is pleased to announce the release of Stream version 3.2.1. We would like to thank customers who provided valuable product input.
New Features
  • Support for Focus Premium Max (400m), Focus Premium (200m), and Focus Core (100m).
FARO Stream 3.2.0 Release Notes - September 2024
FARO is pleased to announce the release of Stream version 3.2.0. We would like to thank customers who provided valuable product input.
Improvements
  • Start by using the "+" button at the top left to create a project. The system no longer creates an empty project automatically.
  • The option to switch between the Orbis and Focus workflows has been removed.
  • In the Structure View, you can now create clusters (for Focus) and sheets (for Orbis) by swiping left at the home level (or at the cluster levels for Focus).
    • Note that clusters are relevant only for Focus, while sheets are specific to Orbis.
    • At this time, Focus and Orbis scan data are not displayed together in the DataView, and they cannot be registered with each other.
  • After migrating from Sphere Legacy to Sphere XG, uploads are now supported for Focus.
Limitations
FARO Stream 3.1.2 Release Notes - August 2024
FARO is pleased to announce the release of Stream version 3.1.2 We would like to thank customers who provided valuable product input.
Improvements
  • Improved cloud connectivity check to make it more robust and responsive.
FARO Stream 3.1.1 Release Notes - August 2024
FARO is pleased to announce the release of Stream version 3.1.1 We would like to thank customers who provided valuable product input.
Improvements
  • Streamlined the Sphere XG login.
  • Added processing options for uploading Orbis projects.
  • Fixed usability issues related to Sphere XG groups and permissions.
  • Uploading a scan now continues even if the app is in the background.
  • Improved robustness of the network check.
Bug Fixes
  • Fixed crashes related to download and installation of firmware files.
  • Fixed occasionally incorrect reported processing state of Sphere 1 projects.
Known Issues
  • When switching between the Orbis and the Focus workflow, there can be an issue with the position of the scan markers in the scans.
    Workaround: Restart the Stream app after switching between Orbis and Focus workflow.
FARO Stream 3.1.0 Release Notes - June 2024
FARO is pleased to announce the release of Stream version 3.1.0 We would like to thank customers who provided valuable product input.
Improvements
  • Download the What's New Power Point presentation for more details on version 3.1.0 improvements
  • Major UI/UX improvements for the Focus scanner.
  • Added visualization of registration connection lines.
  • Several performance improvements.
  • Added a "What’s New” section to the app settings.
Bug Fixes
  • Several bug fixes.
FARO Stream 3.0.4 Release Notes - January 2024
FARO is pleased to announce the release of Stream version 3.0.4. We would like to thank customers who provided valuable product input.
Bug Fixes
Improved user experience following Orbis firmware update completion. The spinning wait cursor no longer keeps spinning after the firmware update successfully completes.
FARO Stream 3.0.3 Release Notes - December 2023
FARO is pleased to announce the release of Stream version 3.0.3. We would like to thank customers who provided valuable product input. This release includes feature enhancements that are designed to increase productivity, mobility and ease-of-use.
Improvements
  • Optimized performance for lists (projects, scans, datasets, etc.).
  • Minor UI improvements.
  • Improved performance for the data view.
  • Improved performance for Sphere XG upload processes.
  • Improved user feedback in cases where mapping couldn't be initiated due to a general error.
  • Implemented a display of the uploading sheet/dataset while transferring to Sphere XG
Bug Fixes
General:
  • Fixed an issue where devices appeared as available even when they were not.
  • Fixed the Service package and log file export via Android’s Nearby Share feature.
  • Fixed the firmware file download interruption when the app was sent to the background (iOS only).
Focus:
  • Fixed a display issue of the "Undo" button for registration.
Orbis:
  • Resolved an issue where a project synced with Sphere XG appeared as modified only after restarting the app.
  • Addressed project upload errors after a previously canceled upload to Sphere XG.
  • Corrected the project naming suffix to adopt the pattern "_N" for conflict avoidance.
  • Fixed erroneous messages during firmware upgrades when an error occurred.
  • Improved handling for users caught on the mapping screen due to a device connection interruption.
  • Adjusted the view area limit to prevent exceeding the right and lower boundaries.
  • Fixed initial lagging experienced during the start of a Flash scan.
  • Stabilized the progress indicator during Sphere XG uploads to prevent fluctuations.
FARO Stream 3.0.2 Release Notes - October 2023
FARO is pleased to announce the release of Stream version 3.0.2. We would like to thank customers who provided valuable product input. This release includes feature enhancements that are designed to increase productivity, mobility and ease-of-use.
Improvements
Focus:
  • Improved icons for Focus near, distance, and far settings
Orbis:
  • The project image now syncs seamlessly with Sphere XG.
  • Project creation dates are now synchronized with Sphere XG.
  • All map zoom levels are accessible in offline mode.
  • We've optimized the communication frequency between devices and Stream.
  • Various minor performance enhancements have been implemented.
  • Numerous cosmetic improvements.
Bug Fixes
General:
  • Fixed an intermittent crash issue during network property checks.
  • Fixed an issue where Stream sometimes failed to reconnect when the device erroneously detected use by another Stream instance.
Focus:
  • When relocating a scan from a cluster to the project root, the notification text no longer displays an empty cluster name. Instead, it says "...moved to the top level."
  • Fixed the problem where getting scan profiles from the scanner sometimes failed.
Orbis:
  • The project name no longer gets lost sporadically when changing the project image.
  • Stream no longer hangs indefinitely when trying to synchronize an invalid dataset (e.g., due to scanner shutoff during scanning).
  • Scan label settings, which had no effect in Orbis mode, have been removed to streamline functionality.
FARO Stream 3.0.1 Release Notes - October 2023
FARO is pleased to announce the release of Stream version 3.0.1. We would like to thank customers who provided valuable product input. This release includes feature enhancements that are designed to increase productivity, mobility and ease-of-use.
Improvements
  • Introducing support for FARO's cutting-edge scanner: The Orbis™ Mobile Laser Scanner.
  • Stream now offers the capability to download and update firmware for both the Focus and Orbis scanners.
  • Introducing a new feature that allows users to set limitations on loading scans from the Focus scanner, providing greater control and efficiency.
  • Improved design that enhances user experience and navigation.
  • When modifying cluster visibility, the view will automatically adjust to display the newly selected cluster.
  • Numerous changes have been implemented to enhance stability, robustness, and overall performance within the app, ensuring a smoother and more reliable user experience.
  • In the data view, you can now show either all scan marker labels, or only the label from the last scan.
  • More details of the in-field registration are stored in the scan project, in both offline and online workflows.
FARO Stream 2.0.2 Release Notes - May 2023
FARO is pleased to announce the release of Stream version 2.0.2. We would like to thank customers who provided valuable product input. This release includes feature enhancements that are designed to increase productivity, mobility and ease-of-use.
IMPORTANT - Before Installing Stream
  • Install Focus firmware 7.2.2 (or later) on your Focus Premium or Focus Core scanner before you use this version of Stream. The firmware can be downloaded from the FARO Knowledge Base or via the online firmware update option in the scanner.
  • If you use Stream with the Ricoh Theta Z1 panoramic camera, upgrade the firmware 2.30.1 (or later) before using the camera with Stream.
Improvements
  • FARO Flash scans now with Ricoh Theta Z1 HDR
    The HDR (High Dynamic Range) setting makes it possible to see details in areas that would be overexposed or underexposed in scans with high-speed or low-noise settings. Stream 2.0.2 with Focus firmware 7.2.2, together with the Ricoh Theta panoramic camera, make it possible to use HDR when capturing FARO Flash scans, giving you the detail of HDR together with the speed of FARO Flash.
Bug Fixes
  • Various fixes to improve stability and performance.
Known Issues
  • In rare cases, high-resolution scans may result in reduced display performance.
FARO Stream 2.0.1 Release Notes - April 2023
FARO is pleased to announce the release of Stream version 2.0.1. We would like to thank customers who provided valuable product input. This release includes feature enhancements that are designed to increase productivity, mobility and ease-of-use.
  • Install Focus firmware 7.2.1 (or later) on your Focus Premium or Focus Core scanner before you use this version of Stream. The firmware can be downloaded from the FARO Knowledge Base or via the online firmware update option in the scanner.
  • If you use Stream with the Ricoh Theta Z1 panoramic camera, upgrade the firmware 2.30.1 before using the camera with Stream.
Improvements
  • The visibility of the top view has been enhanced — especially on tablets
  • The Flash profile selection is now restricted to scanners with firmware 7.2.1 or later
  • Additional performance enhancements have been implemented
Bug Fixes
  • Placing the registration hint marker precisely was impossible because the view jumped when the user applied a long press
  • Streaming panorama camera calibration scans sometimes failed
  • Improved project loading when reopening a large project
  • When connecting to a FARO Core scanner for the first time, no scan profiles were available
  • Live streaming of the first scan after scanner bootup sometimes failed
  • Some bug fixes to prevent crashes
Known Issues
  • Projects with PanoCam scans cannot be uploaded to Sphere if the active cluster is selected. Workaround: Deselect the cluster before uploading.
FARO Stream 2.0.0 Release Notes - March 2023
FARO is pleased to announce the release of Stream version 2.0.0. We would like to thank customers who provided valuable product input. This release includes feature enhancements that are designed to increase productivity, mobility and ease-of-use.
IMPORTANT - Before Installing Stream 2.0
  • We strongly recommend that you uninstall any previous versions of Stream from your device before installing Stream 2.0.  Create a secure backup of all your data before proceeding.
  • Install Focus firmware 7.2.0 (or later) on your Focus Premium or Focus Core scanner before you use this version of Stream. The firmware can be downloaded from the FARO Knowledge Base or via the online firmware update option in the scanner.
New Features
  • Support for FARO Flash
  • The scanner's compass is now used to pre-orientate the scans during registration
  • Added optional sound or vibration when it is safe to move the scanner
  • Added analytics (as opt-in)
Improvements
  • Improved general usability and responsiveness across the App
  • Improved usability of cluster handling
Bug Fixes
  • Improved robustness and efficiency of scan projects synchronization with Focus scanner
  • Improved Sphere upload
Notes
  • This release requires FW version 7.2.0 or later to be installed on the scanner
FARO Stream 1.1.0 Release Notes - January 2023
FARO is pleased to announce the release of Stream version 1.1.0. We would like to thank customers who provided valuable product input. This release includes feature enhancements that are designed to increase productivity, mobility and ease-of-use.
IMPORTANT: Install Focus firmware 7.1.0 (or later) on your Focus Premium or Focus Core scanner before you use this version of Stream. The firmware can be downloaded from the FARO knowledge base or via the online firmware update option in the scanner.
New Features
  • Support for the FARO Focus Core laser scanner, including licensing via Sphere.
  • On-site compensation results can now be shared as a pdf report.
  • Stream now indicates the scanning phase (e.g., "Inclinometer capturing").
  • Scan base names can now be modified per cluster.
  • Added new PanoCam options introduced with the FARO Focus firmware 7.1.0.
Improvements
  • Point-cloud data is now optionally automatically downloaded.
  • The scanner must now be explicitly selected. Previously, when multiple scanners were in the same network, Stream selected one scanner randomly.
  • Sphere processing can now be triggered for projects that were uploaded but not processed during upload.
  • Several usability improvements and bug fixes for the top view.
  • Several usability improvements related to annotations.
  • Reworked scanner detection and connectivity checks.
  • Improved diagnostics related to registration failures.
Bug Fixes
  • Several fixes related to cluster management.
  • Fixed several crash situations.
Known Issues
  • If a scan is assigned to another cluster before the scan is finished, the project synchronization mechanism will fail, so that on the scanner the scan will still be in the original cluster.
    • Workaround: Wait to shift scans to other clusters until the scan is complete.
  • In rare case the streaming of a scan can be interrupted.
    • Workaround: Wait until the scan is finished and it will automatically reload after the scan is complete.
