3D Laser Scanner
Focus3D X
Focus3D X HDR
Focus3D S
Error-Reboot and Select Proper Boot Device or Insert Boot Media in Selected Boot
Symptom:
The Laser Scanner fails to boot and displays the message: “Reboot and Select Proper Boot Device or Insert Boot Media in Selected Boot”
Solution:
  1. Remove the battery/power from the scanner.
  2. Press and hold the on/off button for at least 10 seconds, (this will reset the internal BIOS).
  3. Insert the battery and power up the unit as normal.
