3D Laser Scanner
Focus Core
Focus Premium
Focus Premium Max
Focus3D X
Focus3D X HDR
Focus3D S
Memory Cards Used With the Focus Laser Scanner and Formatting Instructions
The FARO® Focus Laser Scanner stores the recorded scans on a removable SD card. This memory card can also be used to create backups of the scanner settings, to import scanner settings, and to install firmware updates.
The memory card that came with your Focus is correctly formatted and can be used immediately with your scanner. Any other memory card must be correctly formatted before use. For information about using SD memory cards, see the user manual for your model scanner.
Below you can find some general information on how to manage you SD card:
  • Back up your SD card to a hard drive often, and make sure the hard drive is also backed up. Redundancy is key to proper data storage.
  • Store SD cards in a light-protected, hard, padded, and water resistant case.
  • Date and label SD cards clearly.
  • Carry spare, correctly formatted SD cards. If you are having a problem with one SD card, immediately switch to a new one.
  • Avoid filling SD cards completely. Try to keep 25 percent of the card empty.
  • Only use SD cards that meet FARO specifications listed below.
SD Card Requirements and Formatting
The SD card must be formatted in the FAT-32 file system. Although there are many ways to format memory cards, the most reliable way is to use the scanner's Format menu function (Manage > Service > SD Card > Format). If you experience any issues, please always try to format the SD card in your scanner.
Focus Premium/Max/Core
  • SDHC or SDXC cards are highly recommended.
  • Memory cards with a size up to 512 GB have been verified to operate with the scanner. The speed of the card must be Class 10/V30 or better.
FocusM & FocusS
  • Memory cards with a size up to 64 GB have been verified to operate with the scanner. The speed of the card must be Class 10 or better.
Focus 3D/3DX
  • SD, SDHC or SDXC are supported. SDHC or SDXC cards are highly recommended.
  • Memory cards with a size up to 64 GB have been verified to operate with the scanner. The speed of the card must be Class 6 or better.
macOS formatting instructions
If you format your SD card in the Focus scanner, the card will not be recognized on macOS. The following steps will allow you to use an SD card with the Focus scanner and macOS.
  1. In macOS, open the disk utility app.
  2. Identify your SD card. Only use an empty SD card, as all data will be erased.
  3. Choose Erase function.
  4. Choose filesystem format:
    •  If 64GB or larger, choose exFAT
    • If 32GB or smaller, choose FAT32
  5. Erase.
Keywords
memory, storage, data, SD card formatting, SDHC card formatting, SDXC card formatting
