Restore Factory Default Settings for the Focus Laser Scanner
To restore your Focus to the factory settings, click on Manage > Service > Factory Settings.
This function will reset your scanner settings to factory default. Use this option in exceptional cases only.  Your scans, scan profiles, scan projects or operators that are saved on the scanner remain unaffected by this operation.
Keywords: restore, factory, reset, settings, default
