Laser Tracker
Vantage S
Vantage S6
Vantage E
Vantage E6
ION
Si
X
Xi
Dimensions of the Shanked Nests for the 1.5 Inch SMR
All of the Shanked Nests (sometimes called Pin Nests) for the 1.5” Spherically Mounted Retroreflector (SMR) have the same basic dimensions. The only difference between them is the diameter of the precision shank, which is included in the name listed in our product catalog.
Imperial Unit Nests
On all of the Imperial Unit shanked nests, the center of the SMR sits a precision 1” from the bottom surface of the nest and the large circular portion that the SMR sits in has precision diameter of 1.6”. The tolerance of both the height and centering is +/- 0.0005". The length of the shank is 0.450” and the height of the large circular portion that the SMR sits in is approximately 0.42”. The shank diameter has a tolerance of +0.0000" to -0.0005". The shank diameter for each part number follows:
  • 069-90-131 – 0.1250” Shank Diameter
  • 069-00949 – 0.1875” Shank Diameter
  • 069-90-132 – 0.2500” Shank Diameter
  • 069-00948 – 0.3125” Shank Diameter
  • 069-90-133 or 069-00947 – 0.3750” Shank Diameter
  • 069-00946 – 0.4375” Shank Diameter
  • 069-90-134 or 069-01072 – 0.5000” Shank Diameter
  • 069-00944 – 0.6250” Shank Diameter
  • 069-00945 – 0.7500” Shank Diameter
Metric Unit Nests
Metric Unit shanked nests are available with a choice of height offset, either the SMR’s center being precision 1” or a precision 25 mm from the bottom surface of the nest. The height of the large circular portion that the SMR sits in is approximately 0.42” for the 1” offset nests and approximately 10.3 mm for the 25 mm offset nests. The tolerance of both the height and centering is +/- 0.013mm (+/- 0.0005"). For either option, the large circular portion that the SMR sits in has a precision diameter of 1.6” (40.64 mm) and the length of the shank is 0.450” (11.43 mm). The shank diameter has a tolerance of +0.000mm (+0.0000") to -0.013mm (-0.0005"). The shank diameter and height offset for each part number follows:
  • 069-01211 – 1” Offset, 6 mm Shank Diameter
  • 069-01210 – 1” Offset, 8 mm Shank Diameter
  • 069-01209 – 1” Offset, 10 mm Shank Diameter
  • 069-02129 – 25mm Offset, 4mm Shank Diameter
  • 069-01310 – 25mm Offset, 5mm Shank Diameter
  • 069-01311 – 25mm Offset, 6mm Shank Diameter
  • 069-01312 – 25mm Offset, 7mm Shank Diameter
  • 069-01313 – 25mm Offset, 8mm Shank Diameter
  • 069-01314 – 25mm Offset, 9mm Shank Diameter
  • 069-01315 – 25mm Offset, 10mm Shank Diameter
  • 069-01316 – 25mm Offset, 12mm Shank Diameter
  • 069-02609 – 25mm Offset, 15mm Shank Diameter
  • 069-02608 – 25mm Offset, 16mm Shank Diameter
  • 069-01318 – 25mm Offset, 0.2500” Shank Diameter
  • 069-02606 – 25mm Offset, 0.5000” Shank Diameter
  • 069-02607 – 25mm Offset, 0.6250” Shank Diameter
  • 069-01323 – 25mm Offset, 0.3750” Shank Diameter
Keywords: Pin Nest Dimension, Pin Nest Size, Pin Nest Drawing, Shank Nest Dimension, Shank Nest Size, Shank Nest Drawing
