Laser Tracker
ION
Si
X
Xi
Dimensions for the Laser Trackers
Vantage Tracker
Tracker Head Dimensions – 224 x 416 mm (8.8 x 16.4 in)
Master Control Unit Dimensions - 290 x 158 x 214 mm (11.4 x 6.2 x 8.4in) - without filters
316 x 158 x 214 mm (12.4 x 6.2  x 8.4 in) - with filters
Tracker Head Weight  –  12.6kg (28lbs)
Master Control Unit Dimensions - 4.8kg (10.6lbs)
ION Tracker
Tracker Head Dimensions - 311 x 556 mm (12.25 x 21.9in.)
Master Control Unit Dimensions - 158 x 214 x 282 mm (6.2 x 8.4 x 11.1 in.)
Tracker Head Weight - 17.7 – 19.5 kg (39 - 43 lbs)
Master Control Unit Weight -  5.2 kg (11.5 lbs)
X/ XI Tracker with cable coming out of back of the tracker:
Tracker Head Dimensions - 280 x 552 mm (11 x 21  3/4in.)
Tracker Head Weight - 20 - 22 kg (44 - 48 lbs)
X / Xi / SI with cable coming out of bottom of the tracker:
Tracker Head Dimensions - 280 x 535 mm (11 x 21 in.)
Tracker Head Weight - 16 - 19 kg (37 - 43 lbs)
Specifications, descriptions, and technical data may be subject to change.
Keywords: dimensions, weight, size, length, width, height, faro laser tracker, tracker, specs
