Laser Tracker
ION
Si
X
Xi
Error-Archive Function Disabled Message in CompIT When Using the Laser Tracker
Periodically, CompIT archives information that is sometimes useful for diagnostics if you are experiencing problems with the FARO Laser Tracker. If you are not logged into the computer with Administrator Privileges, this archiving of information may not be able to be performed and an "Archive Function Disabled" message will occur in CompIT. After this message occurs, CompIT will abort. This article will provide information on how to correct this error.
Solution
  1. This message can be eliminated by logging into the computer with Administrator Privileges, opening CompIT and running a Self Compensation or Pointing Compensation.
  2. Once the compensation has been run in Administrator Privileges, CompIT will have been allowed to archive the information.
  3. When you then log back into the computer on an account without Administrator Privileges, this message will not occur and you will be able to use CompIT to check and compensate the tracker.
Keywords: Archive Function, CompIT Error
