Laser Tracker
Vantage S
Vantage S6
Vantage E
Vantage E6
ION
Si
X
Xi
Technical Specification Sheets for the Laser Tracker
Vantage S&E
Model Language
Vantages6 Max and VantageE6 Max
Vantages and VantageE
VantageS6 and VantageE6
ION
Language
X and Xi
Model Language
V2
V1
Soon after the release of the V2 tracker, the V1 tracker accuracy specifications were re-written in accordance with the ASME B89.4.19 Standard, therefore the tech sheets are no longer available.
Along with different accuracy specifications for the V1 and V2, the V1 also has a reduced operating temperature range of 4 deg C to 43 C (40 F to 110 F).
Early model V1 trackers were produced with an SADM System (SI) instead of an XADM System (Xi) which did not allow scanning in Absolute Distance Meter (ADM) Only Mode, although the option to upgrade these trackers to an Xi was available. Early model SI trackers that were upgraded to an Xi are still V1 trackers, and they were not upgraded to V2 specifications. V1 Accuracy Specifications are included in the following document:
