Serial FaroArm
Bronze
Gold
Silver
Calibrating the Serial FaroArm Results in Values Close to or Higher Than the 2 Sigma Accuracy
  1. Ensure you are using the correct units (Inches or Millimeters)
  2. Check for debris under sphere, this will result in the 1" sphere not being centered properly.
  3. Make sure you are using the calibration method from the training manual, and that the arm is positioned so that its "elbow point" is not sticking straight up.
  4. Fill out the attached accuracy test form and send to FARO Customer Support.
Click here to download: Acceptance and Accuracy Certification
probe, cal, accuracy
