Serial FaroArm
Bronze
Gold
Silver
Power Supply Specifications for the FaroArm Serial Power Box
Below are some options of portable power that can be used with the Serial Box. The Serial Box is very robust and is capable of running off various power supplies.
Specifications for the power supply are as follows:
  • 100 - 240V
  • .5 - .263A
  • 50 - 60Hz
  • + 12VDC
  • 2.08 A Max
1.) The most recommended power supply would be a UPS (Uninterruptable Power Supply) which has battery backup.
2.) Battery operation is acceptable with a power inverter.
3.) Generators are fine, but they are noisy and expensive.
Warranty for the FaroArm will not be voided if used with the above portable power supplies.
The only caveat is that all portable power systems used must conform to the operating requirements as stated on our labels and in our operating manual of the FaroArm. Uses outside of these requirements will void the warranty.
Keywords: power supply, brick, serial arm, DSP box, volts, amps, gold, silver, bronze
