3D Hand Held Scanner
Freestyle3D Objects
Freestyle3D X
Freestyle3D
Accuracy Guidelines for Best Results with the Freestyle3D
Freestyle3D Scanner
  • For applications requiring the highest degree of accuracy such as reverse engineering, it is advised to turn the Freestyle on and warm it up until the internal temperature stabilizes.
  • Strong dust formation, fog, rain or snowfall may result bad measurements. You should avoid scanning under these conditions.
  • You should avoid scanning objects against direct sunlight. This may result even some gaps in the scan data. The objects or surfaces may have also a noise, if they are directly illuminated by bright sunshine.
  • Highly absorbing or highly reflective surfaces increase the noise. If these surfaces are of importance, you should treat them e.g. with developer or anti-glare-spray.
