Accuracy Specifications for the Legacy Gage FaroArm
Different Gage models have different accuracy specifications and a different method of stating these specifications.  Older Gage models such as Gage, Gage Plus and Power Gages have accuracy specified as 5 microns + L 8 microns / meter where L is the working distance in meters.  1 micron is 0.001 mm
Newer Gage models with Bluetooth specify a Single Point Articulation Test (SPAT) of 18 microns (0.0007 in) and Volumetric Maximum Deviation of +/- 25 microns (+/- 0.001”).  This is the same method that accuracy is specified for all other arms FARO manufactures.  This is the maximum error that can occur anywhere in the Gage arms measurement volume.
A chart presenting accuracy of the older style Gage arms at different working distance is below:
Working Distance Accuracy
Inches mm Inches microns
3.94 100 0.00023 5.8
16.69 500 0.00035 9.0
47.24 1200 0.00057 14.6
For checking the accuracy of the Faro Gage we recommend performing a GAGE block or ring GAGE test in a temperature controlled environment.  If the block or ring are not available, measure a known distance several times.
gage accuracy, gage, accuracy, spec
