USB Driver for the FaroArm, ScanArm, and Gage
Your FaroArm®, ScanArm, Design ScanArm, or Gage works best with the latest driver. This article shows you how to download the latest or earlier drivers.
After servicing or recalibration of your device, plan to download and install the latest driver BEFORE you use the device. The factory provides the most recent hardware improvements when servicing your device, so using the latest driver may be required.
CAUTION: If you use software or hardware from a third-party vendor who makes FARO compatible products, verify the product is compatible with the latest USB FaroArm driver BEFORE you change the driver.
  • If you are using the vendor recommended driver, do not change it.
  • If you are not using the recommended driver and the vendor's product is not compatible with the latest USB FaroArm driver, see the earlier drivers list in this article to find the driver the vendor recommends.
Latest Driver
  1. Download the latest FaroArm driver:
    Version: 6.12.153
    Release Date: 23 Oct 2026
    Download [SHA256]
  2. View the What's New article to learn what has changed in the latest version.
  3. Go to Upgrade the FaroArm USB driver installation instructions.
System Requirements
Processor Intel or AMD
Operating System Microsoft Windows 11 (64Bit)
For a complete list of Windows support by driver version see: Microsoft Windows Operating Systems That Are Compatible with the USB FaroArm Driver
Earlier Drivers
Click here for details about which versions of Microsoft Windows supports different driver versions and computer processors.
Date Version Download
Nov 2025 6.11.77 Offline edition
Aug 2023 6.10.55 Offline edition
Feb 2022 6.9.14 Offline edition
Aug 2021 6.9.12 Offline edition
Jul 2021 6.8.9 Offline edition
Jul 2021 6.7.63 Offline edition
Dec 2020 6.6.7 Offline edition
Aug 2020 6.6.0.15 64- & 32-bit
Offline edition
Jan 2020 6.5.1.4 64- & 32-bit
Offline edition
Aug 2019 6.4.1.2 64- & 32-bit
Offline edition
Feb 2019 6.3.1.5 64- & 32-bit
Offline edition
Nov 2018 6.3.0.11 64- & 32-bit
Offline edition
Oct 2018 6.2.1.9 64- & 32-bit
Offline edition
Aug 2018 6.2.0.26 64- & 32-bit
Offline edition
May 2018 6.1.2.7 64- & 32-bit
Offline edition
Mar 2018 6.1.1.6 64- & 32-bit
Offline edition
Feb 2018 6.1.0.21 64- & 32-bit
Offline edition
Nov 2017 6.0.2.3 64- & 32-bit
Offline edition
Oct 2017 6.0.1.9 64- & 32-bit
Offline edition
Aug 2017 6.0.0.63 64- & 32-bit
Offline edition
Nov 2016 5.8.5.2 64- & 32-bit
Offline edition
Mar 2016 5.8.4.5 64- & 32-bit
Offline edition
Feb 2015 5.8.3.2 64- & 32-bit
Dec 2014 5.8.2.2 64- & 32-bit
Sep 2014 5.8.1.3 64- & 32 bit
Hardware Support Notes:
The latest driver version is compatible with all USB FaroArm and ScanArm models*. Model specific, minimum required versions are listed below.
Model/Device Minimum Required Driver
  • Quantum X
6.11.14
  • Quantum Max
  • Gage Max
6.7.63
  • 8-Axis support for Quantum Series and Edge**
6.3.0.11
  • Design ScanArm 2.5C
  • Quantum Series with Prizm LLP
6.2.0.26
  • Quantum Series FaroArm
  • Quantum Series and Edge with HD/SD Blu LLP
6.0.0.63
  • Legacy USB FaroArm/ScanArm
5.8.5.2
5.8.4.5
* Provided the FaroArm firmware is up-to-date.
**8-Axis support for the Edge requires an authorized firmware upgrade, contact your local sales representative for details
