Disabling Wireless or Bluetooth on the Edge FaroArm
WiFi and Bluetooth can be turned off via the settings in the touch screen of the FARO® Edge Arm.
Note: The FARO Edge Arm can also be built without signal emitting chips. This feature must be specially ordered at the time of purchase. Click here for more information.
Disable WiFi
  1. From the MAIN menu on the Edge touch screen, press SETTINGS.
  2. From the SETTINGS menu, press CONNECTION.
  3. Make sure the WiFi radial button is unchecked to disable WiFi.
Disable Bluetooth
  3. Make sure the Bluetooth radial button is unchecked to disable WiFi.
Keywords
wifi, wireless, ethernet, Edge connection, government services. wi-fi, volatility
