All All - FARO Products
FaroArm FaroArm - All Models
Laser Line Probe Laser Line Probe - Prizm Laser Line Probe - FAROBlu HD/SD V6 Laser Line Probe - Edge HD V6 Laser Line Probe - Edge ES V5 Laser Line Probe - Edge V4 Laser Line Probe - V3 Laser Line Probe - V2 Laser Line Probe - V1
Laser Tracker Accessories Tracker Accessories - All Models Tracker Accessories - Vantage Tracker Accessories - ION Tracker Accessories - Si X Xi
Laser Projector Laser Projector - Tracer Scan Head - Digi-Cube
USB FaroArm
All Models
English
Pinout of the USB FaroArm Auxiliary Port Connector
USB FaroArm Auxiliary Port Schematic (Also known as the Base Option Port Schematic or 7th Variable Options Port)
Below is information for the USB FaroArm Auxiliary Port
User-added image
Pin # Signal Name Description Signal Direction Comments
1 Trigger + The Trigger signal is used to force the FaroArm to immediately issue a Capture signal. From External interface to FaroArm. RS485 differential signal. If (Pin 2 > Pin1 by 200mv) then the FaroArm will initiate a capture.
2 Trigger -
3 GND Logic Ground N/A Connect to Ground
4 NC No Connection N/A Do Not Connect
5 Capture + The Capture signal acknowledges that a Trigger signal has been received and records the current position of the FaroArm. From FaroArm to External interface. RS485 differential signal. When (Pin 6 > Pin5 by 200mv) then the FaroArm has initiated a capture.
Keywords: auxiliary, port, schematic Base Option Port Schematic Variable Options Port
