Platinum
Titanium
Advantage
Recommended Sensitivity Setting for USB FaroArms
The Sensitivity setting of the Arm is different depending upon the type of arm that you have. The sensitivity setting is changed in that Hardware Configuration settings of Measure software.
For Advantage Type arms the setting should be 0.364.
For Platinum and Titanium arms the setting should be 0.182.
These are the factory settings for the arm and it is not recommended to change the.
Stress stop, endstop, sensitivity, diagnostics, hardware config
