Smart Phones Compatible with ScanPlan
You control the FARO® ScanPlanTM with an app on your Android or iOS smartphone. This article lists the smartphones that FARO has tested and verified to work with the ScanPlan. Other current Android or iOS smartphone might also work.
In order to achieve best performance with ScanPlan FARO strongly recommends to use the latest and most modern listed iOS and Android devices. In particular, larger projects and longer scans require a high performance device for the best user experience.
Dimensions
The ScanPlan phone cradle can accomodate most modern phones. The cradles dimensions are:
  • 160mm x 82mm x 8mm (Height x width x thickness)
  • 6.29in x 3.22in x .31in (Height x width x thickness)
See Also
Keywords
compatible accessories, third-party, cell phone, floor plan, 2D mapping, escape plans, crime scene schematics, ground plans, diagrams
