Mobile Scanner
Orbis
Orbis WiFi Stream Settings
In this article you can find Orbis WiFi settings for use in Stream. Ensure you have the correct settings within the Stream app to maintain optimal WiFi connectivity and performance.
Procedure
  1. Connect Stream to the Orbis Wi-Fi network.
  2. Click on the available devices.
  3. Click on the ellipsis next to the selected device.
  4. Select the device settings option.
  5. Check the Device Settings, e.g. Wi-Fi Regulatory Domain. Please select the correct country.
  • Was this article helpful?
