As-Built
AutoCAD
Creating a Floor Plan Tutorial with As-Built for AutoCAD Software
In this 10-minute video tutorial you will learn how to:
  • create and manage slices
  • fit outline plan of walls
  • create a door
  • create a segment for a staircase
  • create a stair case
Tutorial Data
This tutorial shows the typical process of how to generate a building floor plan from a point cloud. You will need to download the accompanying tutorial material to follow along with the video. See the table below to download the tutorial material in your language preference. After downloading and unpacking the zip archive. You will find the drawing files (DWG) as well as the point cloud files.
Creating a Floor Plan Tutorial Data Download
 English
 German
Now open the drawing FloorPlan_Tutorial_xx.dwg
You will see the following:
A point cloud in the AutoCAD format has already been inserted into the drawing. Continue to the video section to view the tutorial video, if you cannot view the video, click here to download this video.
Video
