As-Built
AutoCAD
Getting Started with As-Built for AutoCAD Software
The FARO® As-Built™ for AutoCAD® is the follow-up product of all PointSense for AutoCAD Products. It contains the functionality of PointSense Pro, Building, Heritage and Plant plus additional features. As-Built for AutoCAD is available in many languages.
As-Built for AutoCAD provides powerful tools to derive plans, image plans and 3D models from point clouds for as-built data collection and planning in architecture, construction and engineering. Plant components and piping systems can be automatically detected and recorded with all their parameters. Exact connection points can be determined without modeling. Analysis tools serve for quality control of the modeled object as well as for the determination and visualization of deformations. The integrated feature data capture is useful for facility management and real estate management, as well as for component lists from piping systems or for damage mapping on facades of historical buildings.
Photogrammetry tools are a valuable addition to the inventory and documentation of historical buildings in particular in historic preservation and building research. An interface to total stations complements the range of functions and enables the staking out of points from the design into reality. When measuring the total station becomes a 3D mouse. Measurements are transferred directly to AutoCAD.
Note: Photogrammetry tools and Total Station support is not available in As-Built for AutoCAD version 2024 and later.
What's New?
Learn what's new in the current version... Download
Getting Started Tutorials
Working with Scan Data
Tutorial Creating a Floor Plan:
After this tutorial you will be able to:
  • Create and manage slices
  • Fit outline plan of walls
  • Create a door
  • Create a room height block
  • Create a stair case
Download English Tutorial Download Deutsche Tutorial
Evaluating Scans of Pipe-runs and Steel Constructions
Following tutorials can all be done with the same data set, a scan project of an industrial plant. You only have to download the material once. You can execute them in any sequence.
Download Tutorial Material
Tutorial: Prepare a Drawing for As-Built Plant Tools
  • Load catalogs (Plant Models)
  • Add steel to an Active Set
  • Configure units and parameters
  • Insert a point cloud (RCP file)
Tutorial: Pipes
  • Use scan navigation
  • Create pipe runs efficiently (Walk The Run)
  • Apply Constraints
  • Export the results
  • Create an ISO drawing
Tutorial: Steel
  • Fit steel beams to the point cloud
  • Copy beams
  • Extend beams
Tutorial: Tie-In Points
  • Create and annotate tie-in points
Tutorial: Tank Analysis
  • Define point cloud sections
  • Fit a cylinder
  • Run a tank analysis
  • Import the result to Excel
Capturing Feature Data
Tutorial Area Management:
  • Use the area list
  • Create new room items
  • Enter attributes
  • Create visualizations
Feature Data Tutorial II - Part 1: Data Capture:
  • Collect non-geometrical data linked to geometry
  • Place labels
  • Show attributes in labels
  • Change attribute values
  • Export feature data to tables
Feature Data Tutorial II - Part 2: Inherited Attributes and Links:
  • Link equipment to rooms
  • Ensure equipment has unique key values
  • Move equipment from one room to another
  • Check and Update consistency of collected data
Feature Data Tutorial III - Part 1: Draft a Structure Definition:
  • Plan and draft a structure definition for you own purpose of feature data collection
  • Define what classes of objects/features you need
  • Define attributes for your classes
  • Define relational links between the classes
  • Define Base Classes that other classes may inherit properties from
Feature Data Tutorial III - Part 2: Model and Configure a Data Structure:
  • Create a new structure definition in As-Built for AutoCAD
  • Create new classes and attributes
  • Set links between classes
  • Create classes that inherit from a Base class
  • Export/Save the structure definition
Feature Data Tutorial III - Part 3: Data Capture:
  • Capture objects and features in the structure tree
  • Link objects and features that relate to each other
  • Add attributes to objects
  • Check and create consistency
  • Define the layout of class labels and your structure tree
  • Improve your own structure definition
Archaeological Excavation Tutorial
  • Use the structure view to collect and review data
  • Capture new feature and find objects
  • Link features and finds
  • Open linked documents
  • Enable visualizations
  • Insert a legend
Facade Damage Mapping Tutorial - Part 1: Data Capture
  • Capture areal and linear damage including specific attributes
  • Create links between different types of damage
  • Visualize attributes
  • Insert a legend
Facade Damage Mapping Tutorial - Part 2: Customize a Structure Definition
  • Change the name of the structure definition
  • Customize and add new attributes
  • Sort attributes
  • Add new visualization types
  • Re-use your structure definition
Using Photogrammetry
Tutorial Image Rectification by Control Points:
  • Import control points and define a rectification plane,
  • Load a photo and assign control points to image points ,
  • Rectify a photo by removing central perspective distortion, and
  • Clip and merge photos to one complete image plan
Tutorial Image Rectification by Geometry:
  • Adapt a rectification grid
  • Assign the reference measurements
  • Clip and rectify a photo
  • Add dimension information
Tutorial Oriented Images
Following 3-part tutorial can all be done with the same data set. You only have to download the material once.
Tutorial Oriented Images - Part 1 of 3: Image Orientation:
  • Define a User Coordinate System from the current view
  • Load photos to the drawing
  • Perform the image orientation, and
  • Use the oriented image to create 3D geometry
Tutorial Oriented Images - Part 2 of 3: Import:
  • Import oriented photos from an AgiSoft PhotoScan project
  • Use image management to create view ports
  • Derive 3D geometry from oriented photos
Tutorial Oriented Images - Part 3 of 3: Facade Plan:
  • Load oriented images
  • Prepare viewports
  • Create a façade UCS (User Coordinate System)
  • Derive 3D geometry from photos
  • Flatten geometry to a façade plan
Feature Videos
Looking for more videos... Click Here
Point Clouds
 Scan Navigation (Building)
SmartSnap (Edge or Corner)
 SmartSnap (Real Lowest Point)
Photo-realistic Scan Views
 Section Management
 Clash Detection
 Deformation Analysis
 Scan Navigation (Industrial Plant)
Photogrammetry
 True scale photo rectification
 Merging images in PhoToPlan
 The result of the merging images process
 Adding detailed 2D line work in PhoToPlan
Total Station
 Instrument Setup
 Measure Stairs
 Measure door
 Measure line
 Measure door
Tips & Tricks
 Export an RCP Point Cloud from SCENE
 Create an RCP Point Cloud with ReCap
 Insert an RCP Point Cloud
 Useful AutoCAD Settings
 Bridge Clearance
 Topographic Extractions
