Plane Analysis Output Formats for As-Built for AutoCAD
This article guides you through Plane Analysis Output Formats for As-Built for AutoCAD.
Procedure
The default output format of the plane analysis command is E57. Using As-Built color options, you can create a colored RCP file. These steps are described in the As-Built for AutoCAD - Main Features User Manual, see the follow sections/commands for more information:
- Analysis – Plane – Analysis of planes in a point cloud
- Command Name: PCPLANEANALYSIS
- Analysis – Colorize an analyzed point cloud
- Command name: PCDISTCOLEDIT
