As-Built
AutoCAD
Snap Markers Not Displayed in AutoCAD
Within AutoCAD®, even after turning on snap markers, you may not see the snap marker when picking points on the cloud. This isn't just a visual issue, it actually makes knowing by which planar face you are inserting a flange on impossible when using As-Built™ for AutoCAD Software tools such as “Walk The Run”.
Solution
To correct this issue and get the snap marker to appear:
  1. Use the OPTIONS command.
  2. Click on the Drafting tab.
  3. Under the AutoSnap Settings section, check the boxes next to Marker, Magnet, and Display AutoSnap tooltip. See screenshot below for details.
  4. Click Apply and then OK.
