As-Built
Revit
PointSense
Revit
Feature Comparison & Autodesk Compatibility by Version for As-Built for Revit
The following table lists major feature enhancements added to  As-Built™ for Revit® by version.
As-Built for Revit 2025 As-Built for Revit 2024 As-Built for Revit 2023 As-Built for Revit 2022.1 As-Built for Revit 2022.0 As-Built for Revit 2021 As-Built for Revit 2020 As-Built for Revit 2019 As-Built for Revit 2018 Native Revit
Date of last released version TBD Sep 2024 June 2023 Feb 2023 June 2022 June 2022 Sep 2020 May 2020 June 2019
Date of first released version June 2025 June 2024 June 2023 Feb 2023 June 2022 July 2021 July 2020 July 2019 May 2018
Release Notes Release Notes and Version History
Supported Revit Versions 2023 to 2026 2022 to 2025 2020 to 2024 2020 to 2023 2019 to 2023 2019 to 2022 2017 to 2021 2017 to 2020 2015 to 2019
Supported Windows
Versions (64 bit)
10/11 10/11 10/11 10/11 10/11 10 10 version 1903 or higher 7, 8, 8.1 , 10
Features
Compatibility with Revit 2026 X
Compatibility with Revit 2025 X X
Compatibility with Revit 2024 X X X
Compatibility with Revit 2023 X X X X X
Improvements to Ducting & Piping tools X X X
Align Point Cloud X X X X
Ducting (Fit Ducts , Place Fittings and Align Ducts) X X X X
Improved UX for Fit Pipe X X X X X
Improved efficiency of Place Pipe Fitting X X X X X
New clearer ribbon structure X X X X X X
Compatibility with Revit 2022 X X X X X X
Improved Licensing  X X X X X X X
FARO Customer Experience Improvement Program X X X X X X X
New As-Built Modeler included X X X X X X X
New Clash Detection  X X X X X X X X
Re-organized Ribbon Structure X X X X X X X X
Enhanced User Guidance - FARO Assist  X X X X X X X X
New licensing system with higher flexibility  X X X X X X X X X
User Interface now available in EN, DE, FR, IT, ES, PT, CN, JP  X X X X X X X X X
Software available via digital download now for immediate use after sale.  X X X X X X X X X
3D point snap independent form current work plane  X X X X X X X X X
Fast hide/show point cloud in view X X X X X X X X X
View independent cropping and managing of named point cloud sections X X X X X X X X X
Wall fitting X X X X X X X X X
Automatic creation of new wall types for different wall thicknesses X X X X X X X X X
Automatic wall alignment X X X X X X X X X
Pipe fitting X X X X X X X X X
Creation of new pipe type based in the detected diameter in the point cloud X X X X X X X X X
Automatic alignment of pipe runs  X X X X X X X X X
Fitting of Structural Elements in Point Clouds X X X X X X X X X
Automatic detection of profile types of Structural Elements X X X X X X X X X
Fit 3d model lines X X X X X X X X X
Save model lines as 2D or 3D family X X X X X X X X X
Ortho image from point clouds X X X X X X X X X
Work plane fitting X X X X X X X X X
Intersection lines between reference or model planes X X X X X X X X X
External scan views (VirtuSurv/SCENE) X X X X X X X X X
Scan labels with link to external scan views (VirtuSurv) X X X X X X X X X
Adapted commands for levels, window, doors, openings, columns, beams X X X X X X X X X
Creation of new window and door types from point cloud dimensions X X X X X X X X X
Point cloud regions in the Family Editor  X X X X X X X X X
Insert scaled ortho images in the Family Editor X X X X X X X X X
Creation of construction aids in the family editor from external scan views (VirtuSurv/SCENE) X X X X X X X X X
Toposurface from 3D model lines X X X X X X X X X
Topo surface from 3d construction points X X X X X X X X X
Fit plane with contour X X X X X X X X X
Adapt slabs and roofs to points from point cloud X X X X X X X X X
Deformation analysis of any model surface X X X X X X X X X
Cropped by view ranges  X X X X X X X X X X
Cropped by 3d section box X X X X X X X X X X
Color modes X X X X X X X X X X
Point snap on current work plane X X X X X X X X X X
Planar snap if detected plane is perpendicular to the current work plane X X X X X X X X X X
Support of Autodesk RCS/RCP point clouds X X X X X X X X X X
Scan Import via ReCap X X X X X X X X X X
