Feature Comparison & Autodesk Compatibility by Version for As-Built for Revit
The following table lists major feature enhancements added to As-Built™ for Revit® by version.
As-Built for Revit 2023 | As-Built for Revit 2022.1 | As-Built for Revit 2022.0 | As-Built for Revit 2021 | As-Built for Revit 2020 | As-Built for Revit 2019 | As-Built for Revit 2018 | PointSense for Revit 18.5 | Native Revit |
Date of last released version | TBD | Feb 2023 | June 2022 | June 2022 | Sep 2020 | May 2020 | June 2019 | June 2018 | |
Date of first released version | June 2023 | Feb 2023 | June 2022 | July 2021 | July 2020 | July 2019 | May 2018 | Dec 2017 | |
Release Notes | Release Notes and Version History | ||||||||
Supported Revit Versions | 2020 to 2024 | 2020 to 2023 | 2019 to 2023 | 2019 to 2022 | 2017 to 2021 | 2017 to 2020 | 2015 to 2019 | 2015 to 2018 | |
Supported Windows Versions (64 bit) |
10/11 | 10/11 | 10/11 | 10 | 10 version 1903 or higher | 7, 8, 8.1 , 10 | |||
Features | |||||||||
Compatibility with Revit 2024 | X | ||||||||
Improvements to Ducting & Piping tools | X | ||||||||
Align Point Cloud | X | X | |||||||
Ducting (Fit Ducts , Place Fittings and Align Ducts) | X | X | |||||||
Compatibility with Revit 2023 | X | X | X | ||||||
Improved UX for Fit Pipe | X | X | X | ||||||
Improved efficiency of Place Pipe Fitting | X | X | X | ||||||
New clearer ribbon structure | X | X | X | X | |||||
Compatibility with Revit 2022 | X | X | X | X | |||||
Improved Licensing | X | X | X | X | X | ||||
FARO Customer Experience Improvement Program | X | X | X | X | X | ||||
New As-Built Modeler included | X | X | X | X | X | ||||
New Clash Detection | X | X | X | X | X | X | |||
Re-organized Ribbon Structure | X | X | X | X | X | X | |||
Enhanced User Guidance - FARO Assist | X | X | X | X | X | X | |||
New licensing system with higher flexibility | X | X | X | X | X | X | X | ||
User Interface now available in EN, DE, FR, IT, ES, PT, CN, JP | X | X | X | X | X | X | X | ||
Software available via digital download now for immediate use after sale. | X | X | X | X | X | X | X | ||
3D point snap independent form current work plane | X | X | X | X | X | X | X | X | |
Fast hide/show point cloud in view | X | X | X | X | X | X | X | X | |
View independent cropping and managing of named point cloud sections | X | X | X | X | X | X | X | X | |
Wall fitting | X | X | X | X | X | X | X | X | |
Automatic creation of new wall types for different wall thicknesses | X | X | X | X | X | X | X | X | |
Automatic wall alignment | X | X | X | X | X | X | X | X | |
Pipe fitting | X | X | X | X | X | X | X | X | |
Creation of new pipe type based in the detected diameter in the point cloud | X | X | X | X | X | X | X | X | |
Automatic alignment of pipe runs | X | X | X | X | X | X | X | X | |
Fitting of Structural Elements in Point Clouds | X | X | X | X | X | X | X | X | |
Automatic detection of profile types of Structural Elements | X | X | X | X | X | X | X | X | |
Fit 3d model lines | X | X | X | X | X | X | X | X | |
Save model lines as 2D or 3D family | X | X | X | X | X | X | X | X | |
Ortho image from point clouds | X | X | X | X | X | X | X | X | |
Work plane fitting | X | X | X | X | X | X | X | X | |
Intersection lines between reference or model planes | X | X | X | X | X | X | X | X | |
External scan views (VirtuSurv/SCENE) | X | X | X | X | X | X | X | X | |
Scan labels with link to external scan views (VirtuSurv) | X | X | X | X | X | X | X | X | |
Adapted commands for levels, window, doors, openings, columns, beams | X | X | X | X | X | X | X | X | |
Creation of new window and door types from point cloud dimensions | X | X | X | X | X | X | X | X | |
Point cloud regions in the Family Editor | X | X | X | X | X | X | X | X | |
Insert scaled ortho images in the Family Editor | X | X | X | X | X | X | X | X | |
Creation of construction aids in the family editor from external scan views (VirtuSurv/SCENE) | X | X | X | X | X | X | X | X | |
Toposurface from 3D model lines | X | X | X | X | X | X | X | X | |
Topo surface from 3d construction points | X | X | X | X | X | X | X | X | |
Fit plane with contour | X | X | X | X | X | X | X | X | |
Adapt slabs and roofs to points from point cloud | X | X | X | X | X | X | X | X | |
Deformation analysis of any model surface | X | X | X | X | X | X | X | X | |
Cropped by view ranges | X | X | X | X | X | X | X | X | X |
Cropped by 3d section box | X | X | X | X | X | X | X | X | X |
Color modes | X | X | X | X | X | X | X | X | X |
Point snap on current work plane | X | X | X | X | X | X | X | X | X |
Planar snap if detected plane is perpendicular to the current work plane | X | X | X | X | X | X | X | X | X |
Support of Autodesk RCS/RCP point clouds | X | X | X | X | X | X | X | X | X |
Scan Import via ReCap | X | X | X | X | X | X | X | X | X |
