Send-To-Revit App Installation into As-Built Modeler
The download and installation of As-Built Modeler is included during the setup routine of As-Built for Revit 2019.2 and later. However, the installation process forces a re-start before the entire setup is completed. This prevents the installation of the the "Send-to-Revit" App. To prevent his from occurring please install the software in the sequence listed below.
Note: Before proceeding, save any open files and close all unnecessary programs.
  1. Install As-Built Modeler.
  2. After the install is complete, restart Windows.
  3. Next, install As-Built for Revit. During the installation, the "Send-to-Revit" functionality is automatically registered with As-Built Modeler.
If you have already installed As-Built for Revit (and then installed As-Built Modeler), you can load/install the "Send-to-Revit" App manually.
  1. Start As-Built Modeler. Click the app icon App button.png in the top right corner of the interface.
  2. Click the Apps icon to open the Apps Window.
  3. Click the Install button. Then navigate to the folder containing the app. You will find the SendToRevit.fpp file in the folder: C:\Program Files\FARO\As-Built {version number} for Revit\SendToRevitSceneApp.
  4. When prompted click the Install button.
  5. As-Built Modeler will then confirm the installation. Click OK.
  6. Close any open dialog boxes. The "Send-to-Revit" App should now appear in the main App bar.
