2026
2025
Create Custom Views in CAM2
Creating Views enables the user to save screen shots that can be recalled, and used to enhance reporting.
Download a PDF of this procedure:  VW001: How to create Custom Views
Prepare View
  • Orientate and zoom the CAD view as required
  • Use  visibility toggle  to  show /  hide  the required features (Select  feature - Click ShowHideFeatureEye25.png)
  • Use label toggles to show/hide required labels and style (Select feature - Right Click)
Capture View
  • From the Home ribbon, select Capture View
  • The View panel will open in the bottom LH corner showing the saved views
  • Repeat the above steps to create additional views.
Note: when a view is captured, all visibility and labeling settings are also saved to that view.
Review Views
  • Select a View Data in the View panel and right click to show options
  • User can:
    • Recall view
    • Rename view
    • Delete view
Adding views to a Report
  • Open Report workspace (click ReportIcon.jpg below Features panel)
  • Select Layout template from the Report ribbon
  • Select Include Features
  • From the Include Features window, select the View Data items, and select Add
  • Views will be added to the report.
Note: it is possible to reorganize the order by ‘drag & drop’ in the Report panel.
See Also
Help Sheet, VW001
