2026
2025
Exporting Hard Probed Features to CAD with CAM2
To instruct the user how to export hard probe measured features to a CAD model, that can be used for reverse engineering.
Note: This method is not advised for Point Cloud features, use Export Point Data to Text file.
Download a PDF of this procedure:  EX001: Exporting Hard Probed Features to CAD
Preparation
  • Measure required features
  • Create required alignment / Coordinate System
Method
  • Ensure all required features are measured
  • Open the File tab
  • Select Import / Export on the LH side, then on the Export column, select Measurement Data to CAD
  • From the LH pane, select all the required features that have the suffix ‘Actual’
  • Then use the center Arrows, to move the selection to the RH pane.
  • Select Next
  • Select the required Export format from the pull-down options.
  • Select Next
  • Browse to the save location, and enter a file name
  • Select Finish to export
 The export CAD file can now be opened in a third-party CAD package, such as Rhinoceros as shown below:
Note: If importing the CAD model into CAM2, some features such as circles may not be displayed. To solve this:
  • Open Preferences, then select Display
  • Ensure that Show construction lines is checked.
  • Show constructed lines unchecked
  • Show constructed lines checked
See Also
Help Sheet, EX001
