2026
2025
Exporting Point Cloud Data from CAM2 and Importing into SolidWorks
Quick Steps
Here is all you have to do.
  1. Collect point cloud data and register it in CAM2.
  2. Export the point cloud data from CAM2 as a mesh in a .STL file.
  3. Open and save the .STL file in SolidWorks.
Point cloud data collected with a FARO ScanArm and LLP can be exported from CAM2 and imported into SolidWorks. The export file format is .STL, which imports as easily as opening the .STL file in SolidWorks. Once the file is open, you can use the Mesh Prep Wizard to create an advanced 3D point cloud mesh.
Details
Start by collecting the point cloud data using the ScanArm and LLP, then register the point clouds as needed. The User Manuals for the FaroArm, ScanArm and Gage and CAM2 User Manual show you how.
In CAM2
  1. Click CAM2FileTabIcon.png > Import/Export.
  2. In the Export section, click Export Point Cloud to Mesh.
  3. Select the point clouds you want to export, and click Next.
  4. Apply filters if that is appropriate for your project and click Next. On the next screen, specify where to save the exported file and click Finish. Exporting the file may take some time depending on how large the point cloud file size is.
In SolidWorks
  1. Open SolidWorks and click Tools > Add-In.
    User-added image
  2. In the Active Add-ins section, check Scanto3D.  This setting maybe different depending on your version of SolidWorks.
    User-added image
  3. On the main menu, click File > Open.
  4. In the Open window, use the file type drop down menu to select  Mesh Files. Navigate to the place where you stored the .STL file you exported from CAM2 and click Open. The .STL file opens inside SolidWorks .
    User-added image
  5. Save the file and use the Mesh Prep Wizard to configure a mesh. Refer to the SolidWorks support page for details about using  the Mesh Prep Wizard.
See Also
import file formats, export file formats, file sharing, CAM2, CAD translators, CAD files, 3D CAD files
