2026
2025
Publishing QuickTools to the RPM Control Server with CAM2
Publish an existing QuickTool to a RPM Control Server from within CAM2® 2018. This allows users to access and execute from any RPM Control Station.
Download a PDF of this procedure:  RPM001: How to publish QuickTools to the Control Server
Preparation:
  • A QuickTool created using CAM2 2018, or Measure 10 is required.
  • Each QuickTool should include a report step, containing the items that are to be reported. The report is used to store results into Control Server, for review in Control Center.
  • If guidance imagers are required, these must be added using Imager Creator within CAM2.
Publishing:
  1. Once finalized, save the QuickTool via File > Save As
  2. Select the RPM tab and then select Publish Document
  3. Enter a Name and select Confirm
  4. Once uploaded a confirmation message will be shown
  5. To view the QuickTool list stored on Control Server, from the RPM ribbon select Browse Documents
See Also
Help Sheet, RPM001
