FARO Zone 2D FARO Zone 2D - 2018 FARO Zone 2D - 2019 FARO Zone 2D - 2020 FARO Zone 2D - 2021 FARO Zone 2D - 2022 FARO Zone 2D - 2023 FARO Zone 2D - 2024
Hand Held Scanner 2D Hand Held Scanner - ScanPlan 3D Hand Held Scanner - Freestyle3D 3D Hand Held Scanner - Freestyle3D X 3D Hand Held Scanner - Freestyle3D Objects 3D Hand Held Scanner - Freestyle 2 3D Hand Held Scanner - Leap ST
Laser Scanner 3D Laser Scanner - Focus Core 3D Laser Scanner - Focus Premium Max
SCENE SCENE - 2019 SCENE - 2go App SCENE - 2020 SCENE - 2021 SCENE - 2022 SCENE - 2023
2022
7.x
Importing Scans to SCENE
Depending on the location of your scan data the import process can vary. Refer to the sections below for your situation.
Walkthrough Video
Cannot view the video? Click here to download this video.
Import from a SD Card
  1. Remove the SD card from Scanner and insert the card into your computer.
  2. Open SCENE.
  3. A dialog box will prompt you to import the scans. Click Yes.
  4. On the Configure Project Transfer screen, select the Transfer check box next to the project(s) you want to transfer.
  5. Click Start Transfer.
    • SCENE will create a project folder within the specified import folder and import the scans to it. This import folder location is specified under Settings > General > Project Folder. The default location is C:\Users\username\Documents\FARO\Projects.
  6. You may now Process and Register the scans/project as needed.
Import from Your Computer or Other Location
If your scans are already located on the computer, you can manually import them as follows.
  1. Open SCENE and click Create Project.
  2. Name the project and click Create.
  3. Click the Import tab.
  4. Open the folder on your computer containing the scans. Select the scans and drag and drop them onto the blue circle within SCENE.
  5. The scans will now be imported into the project.
