2022
Keyboard Shortcuts for SCENE
In this article you can find a list of Keyboard Shortcuts that you can use to quickly start some commands for SCENE.
Shortcuts
3D View
Shortcut Description
1 2 3 Set point size of point cloud in active 3D view.
4 Set point size mode to “Adaptive”. This is not a toggle; it only turns the option on.
W A S D or arrow keys Move camera.
I J K L Camera yaw and pitch.
Q E Roll camera.
V Reset camera roll.
R F or PAGE UP PAGE DOWN Pan camera up/down.
T Align camera normal to surface.
X Fly to picked point.
C Toggle Clear View on/off.
Hold CTRL Temporary Orbit camera mode.
SPACE Toggle between Fly and Orbit camera mode.
B Toggle between Fly and Walk camera mode.
BACKSPACE Go back to last camera position.
F2 Next viewpoint.
0 (numpad) Toggle between scale, move, and rotation manipulators with a clipping box selected.
P Toggle perspective/orthographic view mode.
CTRL+T Toggle point cloud visibility.
ALT+P Save image in 3D view.
CTRL+F11 andALT+RETURN Enter and exit full screen presentation mode, respectively.
CTRL+F2 Create viewpoint.
+ Decrease viewing angle (zoom in).
- Increase viewing angle (zoom out).
SHIFT + mouse wheel Zoom mode changes temporarily to the other setting (Positional zoom versus Viewing Angle zoom).
General
CTRL+C or CTRL+INS Copy to clipboard.
CTRL+V or SHIFT+INS Insert from clipboard.
CTRL+X Cut-out selection and copy to clipboard.
DEL Delete selected object.
CTRL+RETURN Edit properties of selected object.
CTRL+A Select all.
CTRL+D Clear selection.
CTRL+P Print.
CTRL+SHIFT+P Print preview.
ESC Cancel and close.
Project
CTRL+Q Close project.
CTRL+S Save project.
CTRL+N Create new project in project overview.
CTRL+O Open project in project overview.
CTRL+W Close active view tab
Area Measurement App
BACKSPACE Remove last point.
RETURN Finish measurements.
I Fix target plane.
ESC Cancel
Volume Measurement App
I Fix target plane.
ESC Cancel.
CTRL+UP CTRL+DOWN Increase or decrease height, respectively.
- + (numpad) Decrease or increase manipulator size, respectively, in either Top Poly or Mesh mode.
- + Change scale in either Top Poly and Mesh mode.
UP DOWN Move polygon up/down in Top Poly mode.
0 Update mesh in Mesh mode.
X Delete vertex/vertices and close holes in Mesh mode.
Y Delete vertex/vertices in Mesh mode. Does not close holes.
3D Measurements
RETURN Finalize measurement.
UP DOWN Zoom camera.
LEFT RIGHT Pan camera left/right.
