Scan Registration Tutorial
Registration is the process of aligning multiple scans in a parent coordinate system using reference positions common between scans. References are common points between scans that are used to create a “best-fit” alignment. The x,y,z coordinate and point name are created on positions like the center of a sphere or planar scan target.
In this 48-minute tutorial for SCENE version 5.5 and earlier, FARO Application Engineer Si Horton shows you different techniques for manually registering scans in SCENE. Here is what you will learn.
  • How to use Correspondence View for Registration
  • Target Registration with Spheres, Checker Boards, and Manual Targets
  • Split Correspondence
  • Top View
  • Cloud-to-Cloud
  • Start/Stop Scan Placement
  • Survey Control
  • Multiple Clusters with Multiple Registration Techniques
Cannot view the video? Download here
Video
