FARO Zone 3D
2026
2025
2022
Creating a Curb or Sidewalk
FARO Zone 3D 2019.5 allows you to quickly create a curb and/or sidewalk and customize it to your needs.
Drawing a Basic Curb
  1. Click the Power Tools ribbon.
  2. Click the Draw Roads icon.
  3. Click the Curb tool.
  4. Click a point to begin drawing.
  5. Click again to place another point.
  6. Double-click when you are finished drawing.
Customizing the Curb
Click the curb and use the Curb Window to customize it.
  • Line Type - Change the curb to a different type of line.
  • Color - Change the curb color or add a texture.
  • Layer - Move the curb to a new layer, create a new layer, or open the layer manager.
  • Type - Change the physical appearance of the curb.
    Note: Use this setting to add a sidewalk to the curb or create a sidewalk without a curb.
  • Align - Change the curb alignment to the drawn line.
  • Segment Type - Make the line straight or curved.
  • Length, Height, Width - Alter the physical dimensions of the curb.
  • Stress Line Spacing - Change the distance of the breaks in the curb.
  • Stress Line Size - Increase the size of the breaks in the curb.
  • Under Surface - Moves the curb beneath the Z-axis.
  • Custom Curve - Use the white triangles to alter a curved line.
  • Lock Aspect - Locks height and width dimensions.
  • Horizontal Flip - Flip the sidewalk horizontally. Note: This will also affect a texture applied to the curb.
  • Show Points - Show the coordinates of each line node.
  • Edit Cross Section - Customize the physical profile of the curb.
